![]() Drives: Yaris Join Date: Jan 2007
Door speakers not working =[
Hey!
Got a Yaris T2 on Saturday. 2 years old. Im 17 - not bad for a first car Only downside is, theres 4 speakers, the 2 dash mounted, and the 2 in the doors, these two arn't working. Any checks i can do on them without pulling apart the door?Think i'll end up putting in electric windows/remote central locking, hopefully find someone with a bit of electronics knowledge to do it though, as god knows what i'd end up doing to it
Look mum no stars!!
Hmmm check if the "fade" option is not set to the rear speakers only. I remember i did that and i was freakin out why my front speakers wasnt workin.
If that doesnt work, then u have to pull apart the door panel and see if the wires are connected and such..... theres some insight of it
Its a 3 door, so theres only 2 dash mounted, and 2 at the bottom of the doors, so the fade options out as theres no rear speakers
dismantling the door.......i was afraid of that =[ |
![]() ![]() ![]() ![]() ![]() Drives: 2007 Bayou Blue!!!!!!! Join Date: Nov 2006
I maybe unfamiliar with your version but are you sure of the dash mounts? In North America only door and rear in the hatchback?
UY |
Definetly yeah, they're on the dash up by the windscreen.
Roar?
but there is still a fade control even though there are no rear. the rear speakers are considered the door speakers
Thanks for the replys
The only option available was the balance, to switch between the left/right speakers.
#8 | |
![]() ![]() Drives: 07 Yaris Hatch 5speed Join Date: Nov 2006
Do you have the stock deck? If it's aftermarket, could be hooked up improperly. Another idea- maybe your "trim" only came with two speakers the dash and nothing else?? |
There is an aftermarket cd player. The original tape deck still exits, with the cd player below it. However, its a Toyota cd player (well, Toyota branding) which would lead me to believe it was factory-installed. So it might be more than the wiring if it was installed officially
| Heatshrink not working :| | jmew0ng | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 08-19-2006 11:26 AM |
| Engine Working too hard? | David81 | General Yaris / Vitz Discussion | 8 | 06-14-2006 11:17 AM |
