![]() ![]() Drives: 2009 Toyota Yaris 5dr hb Join Date: Jan 2011
Will these fit?
Does anyone know if these will fit? They are Enkei's that come off a scion XB. The inside of the rim reads 17 7 jj off 30... I am all stock with no plans to lower or mod. Tires are 205 40 17
Thanks in advance |
yep, those will work fine. The xB is also 4x100 bolt pattern, and it sounds like you have a 17x7" with a +30mm offset.
Yes, they will fit. Tyres will look tiny on stock suspension. They'll be close to flush in the rear, but poke in the front.
What tire size will look the best while not rubbing?
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
you could up them to a 45 profile and it would fill it up better,I had 205/45/17 on mine for a while but with a 42 offset and it only rubed in the front on big dips on the freeway.Was lowered on DF210s....then i went to 40 profile and rubbing was better.....
with a 30 offset and 45 profile on rear you would be really flush so if you lower you have to camber or not go very low....Fronts will be poking,45 profile would most likely work fine on non lowered. |
| Tags |
| enkei, rims |
| Another rear spring option! Honda Fit springs!! | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 10-23-2009 05:02 PM |
| Test drove Rio5, Fit, and Yaris all today | kmf123kmf | New YARIS Purchase Forum | 16 | 10-02-2009 07:48 PM |
| test fit 06-07 Yaris 4 door fog light | winson | California | 15 | 01-13-2009 08:25 PM |
| I test drove a Yaris, Versa and FIT | CanadaCraig | New YARIS Purchase Forum | 41 | 11-29-2008 09:18 PM |
| Test drove: Yaris sedan 5spd, Fit base auto, Civic LX 2dr 5spd | Bounty Hunter | General Yaris / Vitz Discussion | 7 | 07-11-2007 07:40 AM |
