![]() Drives: 2008 Hatchback Join Date: Mar 2016
Pink gunk eminating from Engine Hose
When I was cleaning the battery terminals on my 2008 Hatchback I noticed that a pinkish/purple fluid had crusted over on a cable that leads out from the engine. Can someone help me identify what cable this is and what might be going on?
Thanks! |
That's not a cable - It is a coolant hose going to the throttle body (used to heat the air entering the throttle body). Coolant is the pink fluid that is leaking.
Thanks CTScott. Should I be concerned about this or just clean it up?
I would replace the hose or at least check it and replace the clamp.
I had the same last year. Coolant hose clamp on the throttle body had failed.
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
On that hose it is likely just a weak clamp. However, it is also possible for the hose to be leaking. It should be fixed as it may prevent the engine from sucking coolant from the reservoir (and it can pop off or burst if bad enough).
Do you know the part number for the hose? i searched but am unable to find it.
16264 HOSE, WATER BY-PASS, NO.2
16264-21070 16264A CLAMP OR CLIP(FOR WATER BY-PASS HOSE NO.2) 90467-13054 |
| Tags |
| crusty, engine, hose, pink, purple |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| The last gas question | Tonavi | DIY / Maintenance / Service | 56 | 04-27-2009 08:40 PM |
| engine swap update | Adriaan | Canada | 5 | 03-03-2009 06:21 PM |
| Info regarding Engine change. | sheraz2000 | General Yaris / Vitz Discussion | 5 | 01-08-2009 12:51 AM |
