Old 09-08-2013, 02:46 PM   #1
FluffyFrogg
Drives: Yaris Sedan 07
Power Steering & Radio went out while driving.
Hey all, I wasn't sure where to post this and I couldn't find anything related in the search.. I have a 2007 yaris sedan s.
This morning while driving I noticed my radio went out. All the lights went out in my dash and then my power steering went out. I don't think the car itself stopped running though. About 4 seconds later everything turned on again and the power steering came back on. Anybody know what this could be? There have been two times in the past where I start my car and the headlights seem like they want to go out and the power steering isnt working. I usually just turn off the car and start it again and it works fine after that.
Thanks in advance. :)
FluffyFrogg is offline   Reply With Quote
Old 09-08-2013, 11:05 PM   #2
That is definitely and odd one. There are a few things that could cause it. I would start with checking the battery terminals to make sure they are tight and are not corroded.
Besides that I could see the IG2 relay causing it, if the relay cuts out. The IG2 relay is part of the integration relay in the under hood fuse box.
Old 01-13-2014, 11:22 AM   #3
contraband831
El Huevo
contraband831's Avatar
Drives: 2007 Liftback
This just happended to me, as soon asi got to work, now the battery warning light is on??
Old 01-13-2014, 11:32 AM   #4
That warning light is for the alternator. Check the battery voltage with the engine running to see if the alternator is charging the battery. While you are under the hood, also make sure that it is not a case where the belt is gone.
Old 01-13-2014, 12:21 PM   #5
tk-421
tk-421's Avatar
Drives: 5D-07-LB
This exact thing happened to me a few years ago. The guy who swapped my crank pulley detached one of the cables that is close by and forgot to put it back in. Make sure that plug is secure!
Old 01-13-2014, 03:15 PM   #6
contraband831
El Huevo
everything looks plugged in, belt is on, car starts up, but warning light is still on...looks like i will need a new alternator.
Old 01-13-2014, 03:26 PM   #7
I have a couple of tested spares on hand if you need one.
Old 01-14-2014, 11:55 AM   #8
contraband831
El Huevo
i ordered one yesterday Scott, thank you though... i will post up after the install (friday)
Old 01-18-2014, 05:11 PM   #9
contraband831
El Huevo
Changed alternator, not the battery light comes on along with airbag light at about 20mph??
Old 01-18-2014, 08:13 PM   #10
Where did you get the alternator from? Many of the aftermarket ones are problematic as they do not send out the charging indicator signal correctly.
Old 01-19-2014, 12:29 AM   #11
contraband831
El Huevo
Amazon and i just took it for a drive to see if the lights dimmed and sure enough they spiked and then dimmed, will that be a faulty voltage regulator?
Old 01-19-2014, 09:00 AM   #12
That does sound like the regulator is bad.
Old 07-13-2014, 11:20 PM   #13
MtBeaconGrl
Drives: 2008 Toyota Yaris Sedan
Fluffy this is happening to me how did you resolve this?
MtBeaconGrl is offline   Reply With Quote
kuro-kuro, mga sarisaring katanungan xtremist Middle East 2740 01-27-2020 04:36 AM
ELECTRIC POWER STEERING WHINE???? marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 02-21-2013 05:26 PM
Anyone pulled their power steering fuse? detroiter General Yaris / Vitz Discussion 56 08-10-2011 06:15 PM
Can't find power steering reservoir on '10, is there one? JerseyJeff84 DIY / Maintenance / Service 4 09-07-2010 11:47 AM
How to Be a Street Racer - General Life Guide MDF Off-topic / Other Cars / Everything else Discussions 7 03-19-2007 01:49 PM
