What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
Sedan door speaker wires
Can anyone tell me what the +/- wire colors are for the sedan (mine is an 09)? According to the guide it's supposed to be pink and purple or something like that, but my passenger door was blue/white. The speaker doesn't sound quite right so I think it may be wired wrong. I assumed blue would be + and white -. I'm planning to install the driver door speaker in about an hour and a half, but would like to make sure I get the wires right the first time if possible.
Thanks.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
Did they change up the wiring ? Check out this and see if it helps. http://www.yarisworld.com/forums/showthread.php?t=32971
Heh, Looks like they did something different, Let us know if the other side also has diff colors, if so then looks like we'll have to update the color codes. I grabbed this : Radio 12v blue + radio harness Radio Ground white/black - radio harness Radio Ignition gray + radio harness Radio Illumination green + radio harness Factory Amp Turn-on N/A Power Antenna black + radio harness LF Speaker +/- pink - purple +,- radio harness RF Speaker +/- gray - yellow +,- radio harness LR Speaker +/- black - yellow +,- radio harness RR Speaker +/- red - white +,- radio harness From : http://www.yarisworld.com/forums/showthread.php?t=10195
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 Last edited by _S7V7N_; 06-06-2011 at 05:01 PM. |
Yeah that's what I looked at before, but mine has blue/white instead of pink/purple. I'll report back what the other side is when I get it apart at home.
Ok, so the driver door was the purple/pink as the guide post suggested, so I know that one is correct. However, the passenger door is blue/white instead of grey/yellow. Any suggestions? Any sedan owners remember how they wired theirs up?
Thanks guys. BTW I install Polk Audio DB651. They sound significantly better (even if the other one is wired wrong) and don't require a spacer or anything, you can just mount them with the included bracket.
Look on the factory speaker you removed, does it have any + or - markings on it ?
None that I can see, but if they are identical I guess I could compare it to the other side and see where the pu/pi compare to the blu/w... I think I'll do that when I get back home.
Ha, I guess the guy who assembled that car at the factory had a sense of humor ..Lol
![]() ![]() ![]() Drives: Toyota Belta Join Date: May 2011
The blue wire is negative and the gray is positive, well on the Belta. RHD - Driver's door
If you look closely at the back of the connector you will see which one is positive. |
| 2012 Nissan Versa | Kal-El | Off-topic / Other Cars / Everything else Discussions | 22 | 06-15-2012 04:48 PM |
| Why people choose a 5dr Liftback instead of a Sedan?? | SimmZ | General Yaris / Vitz Discussion | 53 | 05-29-2007 10:28 PM |
