Old 07-23-2011, 04:43 PM   #1
aliasofmike
Drives: 2007 Toyota Yaris 1nz-fe
Enginge bay rattle on passenger side - advice
I've been doing research regarding a rattle that has presented in my girlfriend's 2007 Toyota yaris (1NZ-FE). The car has 104k miles, and the rattling was noticed just recently. It appears to be getting worse.
It seemed like the most common problem was with the water pump. I've taken a look at it, and I don't notice any pink residue, and in general the pulley seems in good repair. I wasn't able to get a great look at it.
The other possibility I am considering is that the noise is coming from the A/C assembly. I found less information on diagnosing this, and I'm not sure where too look. The A/C still works and the noise doesn't increase when the A/C on, fwiw.
The noise is apparent while idling, and increases with RPMs to a point.
It is very hot weather here, and were planning on taking a day trip tomorrow. If it is the water pump, I'm concerned that this would be a gamble/bad idea.
Any advice or questions for me to follow up on, much appreciated.
aliasofmike is offline   Reply With Quote
Old 07-23-2011, 04:59 PM   #2
Z00KA
Z00KA's Avatar
Drives: 2007 Manual Bayou Blue LB
See if the rattle changes or goes away when you cycle on and off the A/C. At least you can eliminate it as a cause if it doesn't change.
Joe
'07 Bayou Metallic Blue LB
Z00KA is offline   Reply With Quote
Old 07-23-2011, 05:53 PM   #3
aliasofmike
Cycling on or off the A/C does not change the noise. Same goes with the fan.
Old 07-23-2011, 10:28 PM   #4
You could loosen the belt and spin the compressor and water pump by hand to see if either feels like the bearings are shot.
Old 07-23-2011, 11:32 PM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
does the car have an in cabin air filter? It would be located right behind the passenger glove box. If not, stuff can get in there and cause noises.
More info is needed. Does it rattle if you hit the gas with the car out of gear?
Colin Chapman disciple
Old 07-25-2011, 01:51 PM   #6
aliasofmike
Thanks for the responses guys.
I'm not too car savy, but it seems to be distinctly coming from the area of the belt driven components on that side of the motor.
Interestingly, we took the car for a 45 minute highway drive, and the noise became intermittent and then stopped. It changed over the course of the drive, becoming clearly a function of RPMs, before cutting out. Before this happened, yes it did rattle with the car out of gear.
Old 07-29-2011, 06:53 AM   #7
JeanaVilee
Drives: None
Thanks your share!I need these things!
toyota service
JeanaVilee is offline   Reply With Quote
Old 08-06-2011, 07:42 AM   #8
c-dub
Drives: 2008 yaris
sounds like the same issue in my girls car. going to try and take a good look today.
c-dub is offline   Reply With Quote
Old 08-06-2011, 12:29 PM   #9
c-dub
Drives: 2008 yaris
did this today. Pulled the accessory belt off and the noise went away. Put it back on and it was back. Pulled out a stethoscope and tried to listen for anything out of the ordinary on the a/c, alt and water pump. Think I can hear the noise coming from the water pump. Every thing else sounded normal, but I can hear the rattle when I put the scope on the water pump near the pulley just not as loud. Any ideas?
Old 08-07-2011, 03:05 PM   #10
c-dub
Drives: 2008 yaris
i'm gonna say change the water pump, did mine today and fixed the issue.
if it sounds like this than its the pump...
http://www.youtube.com/watch?v=M_ggV2MSxTM
Old 08-08-2011, 12:12 AM   #11
victorddr
Drives: 07 Yaris CE
I would say before you change anything. Double check your accessory belt condition and tension first, as your car has ran 104k mile. The belt itself could possibly loosen up or crack occurs between the groove. you may save yourself some $$ before replace any parts by tighten a bolt...
victorddr is offline   Reply With Quote
Old 02-26-2012, 01:00 PM   #12
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
c-dub, just want to say thanks for posting that vid. U just saved me some trouble :) That sounds EXACTLY like mine.
wsladaritz is offline   Reply With Quote
Looking for Passenger side Fender! Marthos Willing to Buy by private party 1 07-21-2011 09:13 AM
Got an extra passenger side headlight laying around? marlondog Willing to Buy by private party 0 09-17-2009 05:54 PM
WTB - Passenger Side Seat Bracket lunjiaow Willing to Buy by private party 3 09-08-2009 06:03 AM
Passenger side airbag question rizaydog In Car Entertainment + Electronics (audio / video / alarm) 0 01-03-2009 08:54 PM
Anyone know how the passenger seat detection system works? rage2 DIY / Maintenance / Service 5 05-12-2007 08:22 PM
