Old 02-11-2012, 07:24 AM   #1
djgab101
djgab101's Avatar
Drives: toyota yaris
Fuel pump
hey
has anyone installed the walbro fuel pump 255lph into there yaris?
i was going to order it and install it myself just wondering how difficult it is? does the walbro fit straight in and replace or does it require some modifications?
djgab101 is offline   Reply With Quote
Old 02-14-2012, 06:55 PM   #2
Requires some small mods. Your stock pump is the size of a "D" cell battery, lol.
I'll try to find my pictures, I'm using the same one.
Old 02-14-2012, 06:58 PM   #3
all I can find so far:
Old 02-14-2012, 09:30 PM   #4
Here are a coupe more:
Fuel sender assembly with pump inside:
Pump assembly removed from the sender (filter end view):
Pump removed:
Old 02-28-2012, 12:59 PM   #5
djgab101
djgab101's Avatar
Just got my walbro fuel pump in good time car barely runs down the road not enough fuel pressure! I took apart my fuel assembly to find that the walbro does not fit into the pump assembly the walbro is a bit to big .... Any possibility I can run the pump outside the assembly ? Or maybe configure a new bracket inside the fuel pump any ideas or feedback?
Old 02-28-2012, 01:02 PM   #6
kou
Drives: 08 lb
Return it and get the 190lph for the MR2 or corolla 255lph they should fit.
Fuel Pump Failure eaglerox DIY / Maintenance / Service 14 03-02-2013 11:27 AM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 04:34 AM
Noisy fuel pump or not johnlui Australia 0 06-16-2011 09:26 PM
i snooped around a lil but couldnt find. does fuel pump come on? severous01 DIY / Maintenance / Service 4 01-31-2010 10:25 PM
