Suspension alignment after new springs?
I've put tanbe NF's on and I'm about to have an alignment. How much will the drop have changed the alignment? can the alignment be put back to factory specs or close?. also, is there any alignment for the back? I notice a little bit of negative camber.
![]() ![]() ![]() Drives: 2007 Orange Yaris Hb 3Drs Join Date: Dec 2006
for the rear there's no worry, it doesn't have toe-in adjustment, and the camber itself doesn't affect tire wear. for the front wheels, NF's will change somehow the toe-in. not dramatically, but it will be a good idea to have it checked if you intend to keep the springs all year around. In fact, this is true for every aftermarket spring available for Yaris. The NF's and the Eibach give the smallest drop available (about 1'').
der Zeck
Any time a suspension component is changed you should get the alignment done.
![]() ![]() ![]() Drives: 07 yaris s sedan Join Date: May 2006
i have nf's on my sedan and i had to adjust my toe a little bit, but i didnt adjust the camber and after about 6k miles i have no abnormal tire wear isssues at all.
2007 S Sedan, NF210's, 5% rear windows, 35% front two, Sirius S50, 15" black konig heliums
Took it into the dealer yesterday and had alignment done. the said they adjusted the toe in but they said that they also adjusted the toe in the back.
I didn't think you could adjust the toe in the back: are they just blowing smoke up where the sun doesn't shine? |
der Zeck
Toe can be adjusted in the rear with shims
| Finishing my suspension | ChinoCharles | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 10-15-2011 09:26 PM |
| Any Yaris hatch rear suspension tweeks? | woof | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 12-05-2009 06:04 PM |
| New 07 Yaris S need advice on 18's and springs | OgDogg | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 48 | 04-27-2009 09:50 PM |
| Lowering Springs - Questions ~ AGAIN ~ | jaspie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 01-16-2007 12:23 AM |
| Front End Alignment after Spring Install? | OK Yaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 08-26-2006 07:46 PM |
