Old 03-07-2012, 11:34 AM   #1
whoknows89
Drives: 2009 Yaris 3 dr liftback
trans leak
My car started chirping as I was driving yesterday and this morning a lifted it up to look and see if I could find anything that was making the noise. I thought it might off been the brakes but they seemed to be working fine, but when I was under the car I noticed that the bottom of the transmission was wet near the drain plug and where the drivers axle inserts.
crappy picture but this is the area
Does anybody know what this could be?
whoknows89 is offline   Reply With Quote
Old 03-09-2012, 04:57 PM   #2
Em_
Drives: 2007 Yaris
clean it dry and see if it comes back
Em_ is offline   Reply With Quote
Old 03-09-2012, 05:38 PM   #3
Jason@SportsCar
Most likely the seal for the axle has gone bad.
Old 03-10-2012, 03:16 PM   #4
whoknows89
You were right. I took my car to the Toyota dealer to have them inspect it, and they found that the left front axle seal is leaking. They also found that the front timing cover is leaking. They are fixing it next week. Thank god for the power train warranty.
Whistle at idle - vacuum leak, induction side RichieRoo General Yaris / Vitz Discussion 17 12-16-2022 06:53 AM
Newbie with an exhaust leak on his '06 Yaris ToYarta DIY / Maintenance / Service 49 01-03-2019 01:50 PM
Just a Wee exhaust leak WeeYari DIY / Maintenance / Service 12 09-02-2015 04:24 PM
Effects of too much trans fluid in the case? (auto trans) detroiter General Yaris / Vitz Discussion 5 02-25-2009 12:08 AM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 11:57 PM
