Old 03-16-2012, 11:36 PM   #1
creatiwitys
Drives: yaris sedan 2077
Exclamation Yaris after market radio not powering...
My aftermarket radio is not powering on after removing the fabric one. I've checked the fuse, (7.5 ACC) but is fine. My fabric radio was working before I cut the cables to install the new radio, Is this cars has a release button to activate the power?? Please help..............
Thanks,
creatiwitys is offline   Reply With Quote
Old 03-16-2012, 11:43 PM   #2
TOLMACH
Drives: soarer
No release button per se
Your aftermarket HU should show signs of life once you feed to it at least
- positive 12 v permanent (yellow)
- negative 12 v permanent - usually black
- acc (may be red, not sure) - 12 v (you should have power here when you insert the key in the keyhole and turn it to the position when your stock radio is on )
check the above (you may use some testing device to check whether the problem is power (any of the above not supplied to your HD) or the HU)
and do not forget to turn ON your new HU
Old 03-17-2012, 01:43 PM   #3
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Why did you cut any wires at all ? The wire harness for our cars cost between $6 and $12.
Old 03-17-2012, 11:50 PM   #4
TOLMACH
Drives: soarer
Thanks,
here is a harness (female side.. your car is male side) with color codes for wires - you can use it to check whether you made connections right (12+ constant, ground and accessory)
http://www.crutchfield.com/p_1207017...ml#details-tab
radio, radio fuse, toyota yaris 2007, yaris 2007, yaris radio
Question on 09 Yaris Radio harness fresnoyaris In Car Entertainment + Electronics (audio / video / alarm) 4 05-04-2009 07:35 AM
Help with 09 yaris sedan kenwood radio? Fiosguy Cosmetic Modifications (Exterior/Interior) 13 11-10-2008 11:59 PM
