Old 10-10-2011, 07:49 PM   #1
Jerkratt
Jerkratt's Avatar
NGK spark plug part number??
im trying to get the NGK irdiums tip 7's the ones that are one step cooler then our stock plugs but cant find a part number for them... can anyone help?
"It hurts more when its wet"
Old 10-10-2011, 09:01 PM   #2
BKR7EIX
Old 10-10-2011, 10:29 PM   #3
MUSKOKA800
MUSKOKA800's Avatar
My OEM's were heat range 5 so I'm now running BKR6EIX but an considering trying 7's as I'm still getting occasional, faint knocking on 94. Knocked like crazy on 91.
Old 10-10-2011, 11:48 PM   #4
Jerkratt
Jerkratt's Avatar
Yea I went to pep boys and got the bkr6eix... Maybe I should return them n get the 7? Also whats the spark plug gap?
Old 10-11-2011, 08:07 AM   #5
I am running the 7's with stock injectors and usually run 93 octane. I ran the OEM 5's for a few days after my install. AFRs were the same with both, but I think you'd actually need to measure exhaust temp to see the difference. I think that most run the 6's. I got two sets of 7's with my SC, so I have just been using them. As for gap, Iridiums are gapped by the manufacturer and should not be adjusted as it will damage the plating.
Old 10-12-2011, 11:02 AM   #6
MUSKOKA800
MUSKOKA800's Avatar
My iridiums came gapped around .44 and I still had some knocking. Later I read that Greddy recommends .33 for the S/C application so I changed mine to .33 and get much less knock now with no apparent downside. Coupled with Ultra 94 fuel it sounds nearly perfect. I still need to have a bung installed for the A/F guage. Then I'll have a better picture.
FYI: the -11 on the end of some iridium plug numbers denotes OE specific pre-gapping at .44 thou. Not all iridiums part numbers have this suffix and local performance shops had no idea of it's meaning so I contacted NGK customer support by phone to get the lowdown.
Old 10-12-2011, 09:56 PM   #7
camelll
Drives: 07 sedan
I set the gap on those plugs to .041" using shims. Following NGK's recommendations on their site. Here is NGK Q&A on plugs, its some good info. If setting the gap on iridium plugs you just need to be careful and only bend the ground electrode.
The stock gap in the manual is .044" and this is the size I ordered in the 7 heat range, I just figured around 30 hp increase so I reduced the gap by .0025 to .003" to .041".
camelll is offline   Reply With Quote
Old 10-12-2011, 09:59 PM   #8
camelll
Drives: 07 sedan
Muskoka here is a pdf that lets you know what the last number is in reference to. Here
Old 10-23-2011, 11:42 AM   #9
MUSKOKA800
MUSKOKA800's Avatar
Thx Camelll !
I had no luck finding that on the NGK website although I knew it must exist.
Old 02-16-2012, 06:15 PM   #10
maxthehax
maxthehax's Avatar
Drives: Echo HB Turbo 6Speed
Thats a nice topic because till I am boosted I use those NGK BKR7EIX with my turbo setup. But I never paid attention to gaping... I tough it was alright to just get ''BKR7EIX'' I have spare set at home and gonna try to mesure them. I have a CEL coming everytime and stay there, I think its a missfire, not completly sure tho, because I have not experienced any problem that I could feel, throttle is alright on load...
maxthehax is offline   Reply With Quote
Old 02-19-2012, 12:46 PM   #11
MUSKOKA800
MUSKOKA800's Avatar
I've just changed to BKR7EIX from 6EIX and have completely eliminated the pre-ignition brought on by the Blitz S/C at low rpm full throttle.
I also get a CEL occasionally which when scanned shows cylinder 2 misfire.
I have switched the cylinder 2 and 3 coil packs and changed to the 7 range plugs and the misfire persists.
CTScott, can you advise which other cylinder specific components could be checked as a source of this cylinder 2 misfire?
Old 02-19-2012, 01:53 PM   #12
Jerkratt
Jerkratt's Avatar
I've gotten 2 Miss fire codes since the supercharger and the NGK 6's install.. both times full throttle once at low rpm and once maybe mid rpm (highway on ramp) my scan gauge didn't find the code the first time I had to use torque (android app) and a Bluetooth OBD port connector and cleared it via phone. Both times my CEL flashed for a few... I just ordered NGK 7's so that might fix the problem for me
Old 03-02-2012, 10:19 PM   #13
MUSKOKA800
MUSKOKA800's Avatar
Will be installing 1ZZ injectors this weekend if the weather holds. Got the same cylinder 2 misfire code recently during full throttle pull onto highway. Put some Kleen-Flo Injector Cleaner through it this week and that seems to have helped, pulling much harder it seems. I look forward to try these larger injectors.
Old 03-02-2012, 10:20 PM   #14
Jerkratt
Jerkratt's Avatar
Do you have part numbers for the injectors? Cause apparently there are different ones...
Old 03-05-2012, 01:02 PM   #15
MUSKOKA800
MUSKOKA800's Avatar
Need a magnifying glass to read: Denso # 23250-22040.
I took them to the dealer to get new insulators and o-rings. The parts guy said they were most likely from a Corolla but he couldn't determine what year or engine.
Old 03-05-2012, 01:27 PM   #16
That part number could be from and 04-07 Corolla (1.8L), 05+ RAV4 (1.8L), or 99-05 MR2 (1.8L).
Old 03-27-2012, 08:06 PM   #17
MUSKOKA800
MUSKOKA800's Avatar
Still throwing the cylinder 2 misfire code after installing the 1ZZ injectors although the first code throw after install was "system too rich" which has not re-appeared since. It does seem rich initially after a cold start-up but not so after a 15 seconds of warm-up.
I'm starting to lean in the direction of a Blitz wiring problem. Never saw any codes before the install but get the cylinder 2 misfire code almost every full throttle pull since getting boosted. May have to strip the harness clean and look for a bad connection. A spring project I suppose.
part number/ price for 60/40 seat nerd_vitZ Cosmetic Modifications (Exterior/Interior) 7 12-27-2008 03:08 PM
Anyone know the dealer part number for the 09 S kit 808yarisLB New YARIS Purchase Forum 5 12-08-2008 11:38 PM
Part Number?? nick1983 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 04-12-2007 02:43 PM
A quick favor... I need a part number ChinoCharles General Yaris / Vitz Discussion 5 04-10-2007 09:36 PM
HELP: JDM Armrest Console Box part number GabL Cosmetic Modifications (Exterior/Interior) 7 10-25-2006 12:12 AM
