![]() Drives: 1.5L SuperRed Yaris (TS) Join Date: May 2011
Correct Oil Pressure??
Today I finally completed the oil press. gauge install. I just wanted to know what pressure readings are correct or what should be the correct range.
The gaunge that I installed is a mechanical one, not an electric with a sender. My current readings are: 1- Around 75 P.S.I. idle speed 2-85 PSI @ 2000 rpm 3-100 PSI @ 5000 rpm I believe that these reading are TOO high! Can anyone help me? Since I have no idea on this readings. Video of the gauge when operatng. http://www.youtube.com/watch?v=XqMpH...TMTzoCoECb5bM= |
seems pretty normal to me. what is your idle pressure cold and hot? should be lower when hot
advocatus diaboli
Drives: 07 Yaris hatch Join Date: Mar 2011
I have an electric(Autometer) gauge hooked up to a an oil filter sandwich adapter and I get the following(roughly) on 20-50 Valvoline VR1 dino
Cold(coolant temp of >180deg) Idle 20-40 5,000(ish) 80-100+(the gauge blinks @ 100) Warm(+185deg coolant) Idle 7-20 5,000(ish) 75-90 Coolant reading are pre-radiator and are generally +7-10 above the Scangauge...wherever it gets it's info from.
-Type 07 FFL- ![]() My odometer 03/11 http://i205.photobucket.com/albums/b...a/2843ed85.jpg |
Thank you for your info.!!! I was starting to worry but since my gauge is not a very expensive/accurate one, your readings are pretty much the same as mine. After an hour of constant driving the idle pressure drops to the 40 - 45 PSI range. Also when hitting 2000 rpm's it drops to the 75 - 80 PSI range.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 09:14 PM |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 08:18 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 05:22 AM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
