![]() ![]() Drives: Toyota Vitz 2007 facelift Join Date: Jan 2012
chirping sound in the morning or after a long time parked
Recently I have been hearing chirping sounds on the driver's side coming from somewhere under the hood. It only happens in the mornings or after work when the car has been parked for a long time.
It usually goes away after a few minutes when the engine is warm I suppose and I never hear it until the next morning. Could it be the belt that needs replacement? The car is a Vitz 2007 model. Thanks in advance |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
Sounds like the serpentine belt (accessory belt). Could also just need to be re-tightened.
Mine sometimes sounds like that when it's cold in the mornings. |
Not quite a noob
Definitely the belt. To be sure, and if you want to check, go take a look at it. On the "inside" of the belt (the side with the ridges) you'll see cracks if it's old.
Mine squeels because it's new, but I am too lazy to go tighten it. |
![]() ![]() Drives: 2011 Yaris sedan Join Date: Mar 2012
I also support the theory of a belt. If the car has 50 or so thousand miles on it just throw the 20 or so bucks at it to change the belt. Also it never hurts to go over the pulleys with some scotch brite. Every time you hear that squealing and chirping its the belt slipping. and it either leaves behind bits of the old belt causing a slick spot. Or something is built up on the pully resulting in a slick spot so throwing a new belt on there would be silly.
You could also try yanking a little harder on the alternator. Just losen the two bolts put a long hammer, axe, broom (use wood as not to damage the engine (and watch where you put that thing no need to put a hole in the engine) And just pull it a little tighter. could fix it could just bandage it till you can get a new one Best Luck Sean Scott |
Wow!!! some good info.
Thanks guys will definitely change that belt and the scotch brite idea is good too :) |
also i must say (and im sure you already knew this and im not trying to demean you) Do it once the belt is off and the engine is not running lol.
![]() Not that you would try to do it with the car running but im sure there are people who would try but dont do it. nobody needs to go to the hospital today ![]() again i know you probably wouldnt but anyone who likes this idea please dont do it with the engine running. you would be amazed what some people would try. Good Luck Sean Scott |
![]() ![]() ![]() Drives: 07 Toyota Yaris Join Date: Feb 2012
i also have the same problems but my chrip is when i let off the clutch and it grabs theirs a chirp. but it only does it once in the morning then never again? idk what that could be
(i have manual btw)
Angry Bird Crew #1 ![]() ![]() |
![]() ![]() ![]() Drives: Black '08 Yaris Hatch S Join Date: Aug 2011
I get this occasionally. Leads be to believe it isn't the belt. If it was a screech I'd be more willing to accept it was a belt; but it only seems to happen when the clutch is movin around. Maybe I just need to grease something.
-Will- |
| Get your post counts here! *read 1st post for rules* | Astroman | Off-topic / Other Cars / Everything else Discussions | 3414 | 11-04-2012 10:03 AM |
| New Sound System - Sound Issues | click.mine | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 03-20-2009 04:11 AM |
| one of the funniest things i've read in a long time | TinyGiant | Off-topic / Other Cars / Everything else Discussions | 6 | 02-13-2009 01:35 AM |
| Avoiding Defrost setting for long periods of time | GeneW | Fuel Economy Forum | 1 | 12-24-2008 02:42 AM |
| long time lurker, first time poster | tekmoe | New YARIS Purchase Forum | 1 | 10-04-2006 01:43 AM |
