Old 03-27-2011, 11:13 AM   #1
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
Spark Plug Problem
We switched out my spark plugs around 1am last night, then put everything together and called it a night. This morning when i fired it up, the car sounded loud and slow. Misfire I assume? When we made a 2am walmart run, the ONLY fitting spark plugs wal mart had were 2 copper and 2 platinum...was it possible that's what caused the bad idle? Also, when placing the spark plugs in, do they snap or pop in? maybe only 2 are in correctly? I'm not sure, but it doesn't sound good.
Any suggestions?
Did i void the powertrain warranty by switching plugs?
Club SHIFT
Old 03-27-2011, 11:37 AM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
did you check the gap on the new spark plug.. i dont trust the manufacturers stock gap..also did you make sure you lined up the same ignition coil for each plug..
Old 03-27-2011, 11:39 AM   #3
TickleTimeTim
Free Mustache Rides
how big do you recommend the gap should be? i pulled the ones i bought straight from package and put them in without tampering. Gonna go to auto zone and buy a full set of iridiums after work today and try this again.
Club SHIFT
Old 03-27-2011, 11:43 AM   #4
marcus
toyota
marcus's Avatar
i havent really check ..i believe its 1.0 mm or .039 inch
http://www.scribd.com/doc/8679181/20...al-13-Ignition
Old 03-27-2011, 11:46 AM   #5
TickleTimeTim
Free Mustache Rides
ill do that today and hope for more luck, thanks. it's 3924 we need right?
Club SHIFT
Old 03-27-2011, 11:47 AM   #6
marcus
toyota
marcus's Avatar
not sure what 3924 is.. and i think we got ngk iridium on our yaris stock which is a very good spark plug dont relace it with a crappy one..
Old 03-27-2011, 11:52 AM   #7
TickleTimeTim
Free Mustache Rides
i want the same plugs, but new. hoping auto zone carries them. i think 3924 was the fitment. when i went to get plugs i had to look it up in a phone book of spark plug sizes.
Club SHIFT
Old 03-27-2011, 11:57 AM   #8
TickleTimeTim
Free Mustache Rides
3924 is for autolight but 5563? or something like that is ngk (that's what auto zone guy just said.)
Club SHIFT
Old 03-27-2011, 12:19 PM   #9
severous01
go get some ngk's from autozone or oriley. they're awesome and cheap.
Old 03-27-2011, 01:34 PM   #10
TickleTimeTim
Free Mustache Rides
yeah, gonna grab some ngk's and a spark plug gap tool. then i found a place that is gonna let me give them a water pump and belt to put on for me. (the wife isn't liking the fact that every time i "fix" my car it gets worse)
....but i call that learning
Club SHIFT
Old 03-27-2011, 05:26 PM   #11
TickleTimeTim
Free Mustache Rides
got the following codes
p0300
p0303
p0304
first is misfire right? what are other two?
Club SHIFT
Old 03-27-2011, 05:28 PM   #12
TickleTimeTim
Free Mustache Rides
think i just found that means cylinder 3 and 4 misfiring, is 3 and 4 on my right or left when standing in front of car?
Club SHIFT
Old 03-27-2011, 06:23 PM   #13
TickleTimeTim
Free Mustache Rides
ah ha, had the ignition plugs in the wrong sequence. dropped car off for water pump and belt to be replaced
Club SHIFT
Old 03-28-2011, 08:14 PM   #14
TickleTimeTim
Free Mustache Rides
andddd..... it's now running squeak free after a $277 mechanic fee.
Club SHIFT
Bosch 4501 Platinum IR Fusion Spark Plug daf62757 Fuel Economy Forum 25 06-19-2014 02:16 PM
Spark Plug ubospawis Middle East 11 09-01-2010 08:55 AM
Do we need to regap our spark plug? marcus DIY / Maintenance / Service 2 08-31-2010 10:53 PM
spark plug gap Hard_Yaris DIY / Maintenance / Service 2 06-10-2010 05:23 PM
spark plug 33lam Performance Modifications 25 12-23-2008 04:40 PM
