View Poll Results: Spacer or no spacer?
SPACER! 4 57.14%
NO SPACER! 3 42.86%
Voters: 7. You may not vote on this poll
Old 01-24-2014, 07:13 PM   #1
mpcv2000
mpcv2000's Avatar
Drives: 2004 Echo HB Hatchback 2 Door
Echo HatchBack 15X6.5" 42ET Nitto NeoGen 205/50R15 . Rear Spacer or not !
I just got my summer wheel today and I was unable not to test fit them.
Close out wheels from Tire Rack .
MSW 15"X6.5" 42 ET and with some Nitto NeoGen 205/50R15 bought at Tire Discount Direct.
1st picture is no spacer front and no spacer rear.
This one I've added about +10mm washers on the back to see what it looks.
( I do this only for looks by the way ) and I think I like it better but on some angle it's not the best look.
I took some measurement and if I'm not mistaking there is about 20mm width difference between the front and rear "hub to hub" outside so with a +10 I'm cutting this in half and I don't have aggressive driving so no need to roll the rear fenders .
I have Tanabe DF210 up front 1.5" & some innexpensive eBay coil springs on the back so the drop is moderate .
I have to make up my mind on Spacer or not.
I'll try to post some different angle shots tonight.
mpcv2000 is offline   Reply With Quote
Old 01-24-2014, 07:41 PM   #2
mpcv2000
mpcv2000's Avatar
Other angles.
No spacer ( always talking about the rear ) :
10mm spacer :
No spacer :
10mm Spacer :
No spacer :
10mm Spacer :
With spacer still :
Old 01-24-2014, 07:41 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
I like no spacers ....I for one do not like flash look on car ,tire with fender or tire out that is just my opinion. ?.with spacers it just looks out of place.
Old 01-24-2014, 07:51 PM   #4
mpcv2000
mpcv2000's Avatar
I agree with you , I may try 5mm just to see.
They are just regular 1/2" Home Depot Style washers , right now I have 4 on each studs and obviously I'm not driving the car anywhere with a setup like that .
I bought them today just to see how it looks with spacers before buying some because I don't know if I will like it neither how thick I want them if I ever go that way.
Old 01-24-2014, 07:43 PM   #5
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
PS looks awesome
Old 01-24-2014, 08:15 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Must say cool way of finding out proper fit...I would say maybe 5mm in rear...im 42 offset too with my new summer wheels on a 07 yaris looks just fine ya maybe less offset in the rear would be cool..but im fine with it also dont like what spcers do to wheel bearings.
Old 01-24-2014, 08:18 PM   #7
kimona
kimona's Avatar
Drives: 2014 White VITZ
Wheels and tyres look great! (I replaced the original Bridgestones with Nitto Neo Gens; handling was outstanding, but highway wander was terrible). I like the no spacer photos best.
Old 01-24-2014, 08:34 PM   #8
Did you have a rear sway bar? I have been running 16" 205 Neo Gens on my TTE wheels for the past two years and they have been excellent with no highway wander from them. My only complaint is that they are pretty noisy.
Old 01-24-2014, 08:58 PM   #9
kimona
kimona's Avatar
Rear TRD anti-sway bar improved stability and showed some decrease in highway wander. But, the right tread pattern completely eliminated highway wander without a rear anti-sway bar.
Old 01-24-2014, 08:44 PM   #10
mpcv2000
mpcv2000's Avatar
Thanks for all the inputs.
I love the NeoGen , I never had that feeling on my car ( Hwy Wander ) but never had those on a Echo either .
I've been using the NeoGen up front on my cars for the past 10 years .
I had some on a 1989 Mazda and on a 2000 Mustang GT and always love them but I don't do any agressive drive or lapping , etc.
Old 01-26-2014, 08:44 PM   #11
mpcv2000
mpcv2000's Avatar
2nd test :
My guess was 4 washers = 10mm and I was right on.
so I'm cutting it in half and I'm right at 5mm .
This is going to be it. I have ordered 2 X 5mm spacer.
I like it better.
Front looking to the rear
I'm not even close to put those wheels on , I'm on winter mode for at least 2 more months , it will give plenty of time for my spacers to arrive.
Old 01-26-2014, 09:17 PM   #12
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Looks good with 5mm ...im in winter mode too two more months sucks so sick of snow lol
Old 01-28-2014, 10:34 PM   #13
Viperoni
Drives: 2005 Toyota Echo
By default, the Echo's more "tucked in" the rear than it is in the front... but that's because the rear has zero camber gain and rubs a bit more with the same wheel/tire package I've found.
I like the look of the 10mm spacers, but you'll probably rub with a 205 tire....
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Old 01-29-2014, 04:58 AM   #14
mpcv2000
mpcv2000's Avatar
Can't wait to spring to give the new setup a try.
Old 02-10-2014, 08:14 PM   #15
Radvr6t
Toyota Echo NOOB!
Radvr6t's Avatar
Drives: 2005 4dr Echo hatchback
Should have gone 195 55 r 15 and with the 10mm and it would prob not rub. It still looks good with the tires on it and the 10mm.
Post up where you are gonna get spacers from , I know i might need a set also for my Schmidt wheels im doing on my echo hatch.
2005 Echo hatchback Project (Silver)
Instagram: Lawrencephotography
Radvr6t is offline   Reply With Quote
Old 02-10-2014, 10:32 PM   #16
mpcv2000
mpcv2000's Avatar
I bought some inexpensive eBay billet HubCentric Wheel Spacers 4x100mm 0.20" ( 5mm ) 54.1mm bore that I paid $19.99 a pair free shipping to Florida , they came in a while back but I live in Montreal and should go down to Florida next month to pick up all kind of stuff I'm having shipped there.
Went down there last fall brought some stuff back and I'll do the same again next month.
I also bought some camber bolts because I think I may be in need of some positive camber a little but I'll find out this spring. I'll put them in anyway.
