ヤリスワールド
Drives: 2008 HB Join Date: May 2010
Alignment question ? 90% street / 10% race
Any help would be cool.....
I am thinking of going with. -2.0 degrees camber in front with zero toe. Car is going to be 90% street,10% light weekend ac race. I have tokico hts,eibach prokit springs,trd sway,15 inch wheels,gt spec braces,Etc. Still thinking on tires we will use ?? |
what type of racing you doing? full track or autocross style?
that is a very good general setup you got going. i say get a temp gun and some tire chalk. chalk the sidewalls and after your first run/lap. check the inside and outside of the tire tread and see what you got. try to get the camber just right to spread the heat across the tire. as far as tires, im a bit lower then you but i run 225/50/15. i have to roll the fenders thought and i cut the wheel well liner out a little bit. but 215 should work just right i believe. depends on how much ur willing to sacrifice for more grip =) |
ヤリスワールド
They have a full track here and we thought we would give it a try,been in the corvette, trans am 1/4 mile race crowd since 80s and want to try a whole new type of raceing and car type.
Thanks for input !! |
-2 is good. Going to put in a little negative in the rear too?
I run -3 front/-2 rear and the car feels great with that.
![]() Drives: Acura TSX Join Date: May 2012
Going to bring this thread back to life because I don't want to start a whole new one. If i want camber to be -3 in front and -2 in back, do I need to install something before taking the car to an alignment shop? My car has TRD springs, shocks and rear sway, would you say my rear camber should be ~ 2/3 the front? Um looking for a fun setup, if the tires wear a tad faster, but the car handles noticeably better, its worth it.
![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
I'd worry about tire life with that much camber, personally I run -1.5 camber and -0 toe all around and all's good.
The car will handle better with, say, -2.5 camber though.
2006 Saturn Ion Redline 2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold 2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped |
| Stay tuned | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 1320 | 11-21-2021 10:03 PM |
| Yaris In Forza 3 | whooppee777 | Off-topic / Other Cars / Everything else Discussions | 61 | 04-03-2010 04:36 PM |
| Alignment Question | gsf1200m | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 10-16-2009 10:35 AM |
| understeer | DOMAV | General Yaris / Vitz Discussion | 31 | 09-30-2009 07:01 AM |
| TRD rear sway bar...street or race setting? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 02-08-2009 02:26 AM |
