Old 02-24-2011, 02:53 AM   #1
dante2086
Drives: Toyota Yaris 07
Something's wrong with my engine.
First of all, the check engine light is constantly on. And for the love of me I can't find a good place to do a diagnostic in my region.
And when I drive, when I approach a speed of like 140 kmph, the check engine light starts flashing, then I feel this resistance, like the car is slowing itself down. Prior to this, my yaris could go 170 without coughing.
Oh, and it stutters when I start it in the morning. But starts fine the rest of the day.
dante2086 is offline   Reply With Quote
Old 02-24-2011, 03:03 AM   #2
big lo
big lo's Avatar
Drives: 2007 VIOS
I had something similar to you, what I did was unhooked the battery and the system reseted it self, I had a friend scan my car and found nothing. But doin some research I found that it has to do with the throttle sensor. For the other question sounds like you'll be needing a starter soon, I hope that helped
Old 02-24-2011, 03:15 AM   #3
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Going at those speeds with an engine light on and the engine acting funny is a sure recipe for mechanical disaster.
You may want to get that car to a reputable garage to get it sorted or you will be one of the people Thomas Tusser was thinking about when he coined the phrase =
“A fool and his money are soon parted.”
Old 02-24-2011, 03:24 AM   #4
boyer
boyer's Avatar
Drives: Vios/Yaris sedan
you should check your O2 sensor, plugs, TB..
boyer is offline   Reply With Quote
Old 02-24-2011, 07:38 AM   #5
dante2086
I did take it to a so called reputable garage, the light went off, and 3 days later. Guess what, the light came right back on.
Old 01-20-2013, 02:58 AM   #6
jambo101
jambo101's Avatar
2 years since the original post..
Did it ever get fixed?
What was the problem?
Have Yaris will travel..
Old 02-24-2011, 09:21 AM   #7
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Take the car to a trusted garage (or a dealer) that can read the diagnostic codes and tell you whats going on. The fact you have a drivability issue and the check engine light is flashing indicates the need for immediate attention. As mentioned above you need to do this immediately!
-The Fitful One
Old 02-24-2011, 10:44 AM   #8
Vinceb
Drives: 2008 5 Speed Sedan
MIL light on is a problem detected, MIL flashing is serious problem or recurring problem. CTScott just had a post on here recently about jumping 2 pins on the plug for the code readers and getting a morris code style number to figure out the engine code problems, maybe he can help.
Vinceb is offline   Reply With Quote
Old 01-20-2013, 02:11 AM   #9
xchronox365
Drives: 2009 Yaris Sedan
I had floored it in mine one night and my light came on and flashed for about 30 seconds then stayed lit. Come to find out it was a misfire in one of my cylinders. replaced spark plugs cause they were cheap easy and fast. 1 month after that, it did it again, first time it was cylinder 4 this time was cylinder 3, guess what, bad COIL PACK. Just ordered a new one of ebay ran $16.45. I believe that to be the issue, if otherwise ill post more but maybe that will help you.
xchronox365 is offline   Reply With Quote
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
Gearbox/diff squeak, poor engine braking Kiz DIY / Maintenance / Service 8 08-01-2009 09:35 AM
90% on short trip. What to do to protect engine? lh59 DIY / Maintenance / Service 22 12-17-2008 09:02 AM
wtb 1nzfe engine blown or working turboyaris Items for Sale by private party 5 04-08-2007 02:03 PM
