![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
changing transmission fluid (automatic)
I did a transmission fluid change in May, everything is good. But I heard some poeple say I need to change twice or even the third time to get rid of all the old oil. Is this necessary? If so, how long should i wait between each change?
Thanks |
If you just dropped the pan and drain it from there you only got 2 0r 3 quarts of the ~8 that are in there.
You could do that a dozen times and not get it all. Some shops have the setup to get it all and it involves hooking up to the transmission lines that run to the radiator (or something) This pumps the new stuff in while pumping the old stuff out and is about the only way to "change' the oil in it. Which isnt necessary unless you drive under really adverse conditions. Im not sure it is even then.
Ok then tell me how many quarts of oil in that thing?
Thanks guys, I asked my dealership they said it only needs to be changed once, and yes about 3 quartz.
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
| Can non-Toyota dealers/repair shops replace transmission fluid w/o "special equipment | lejulie | DIY / Maintenance / Service | 10 | 10-23-2011 07:35 PM |
| So when DOES the transmission fluid need to be changed | dutchy999 | DIY / Maintenance / Service | 12 | 09-06-2011 05:18 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
