![]() Drives: 2012 Toyota Yaris L, 5 speed Join Date: Oct 2011
Fuel Economy Reports
I see the 2nd generation discussion area has a Fuel Economy topic so I decided to add one for our third generation Yaris.
On two tankfuls I got 43.05 and 43.15 on a 2012 5 speed manual Yaris L. This was using non-oxygenated fuel, as I live in the Colorado front range, but am in a county that does not require oxygenated fuel (extra ethanol). Oxygenated fuel in use in the Denver metro area from October 15 to March 15 gives you about 10% poorer mileagethis is based on my experience on my 2000 Eldorado. . Last edited by KentSzabo; 11-21-2011 at 07:45 PM. |
![]() Drives: 2012 Super White Yaris SE Join Date: Nov 2011
You're getting great FE. Do you drive a lot of high way?
I drive about half city and half highway. I filled up today at 201 mi @ 6.8 gals = 29.55 MPG My Brother filled up today for the first time, but he does a lot of city and local driving. He drove 176 mi and filled 6.9 gals to full. So 25.50 MPG. We're from the chicago burbs. We have a lot of additives in our gas. I believe we have our winter blend already. I want to see how much MPG we over the progression of time, but I can't wait to see what we get in the summer time with the summer blend. |
90% highway driving, but up and down mountains from 8800 ft to 5700 ft and back to 8800.
2000 VW Golf TDI, 5 Speed, 48 MPG 2000 Cadillac Eldorado ETC, Auto, 23 MPG 2004 Dodge 3500 Auto, Dually, 6" Lift, 36" Tires, 4" Dual Stacks, Predator, 20 MPG 2012 Toyota Yaris L, 5 Speed Manual, 46.4 MPG |
#4 | |
![]() ![]() ![]() ![]() Drives: 2014 yaris 5 speed Join Date: Aug 2006
" On two tankfuls I got 43.05 and 43.15 on a 2012 5 speed manual Yaris L. "
. Well done .
can you guys verify how close the computer average mpg is to the actual mpg (miles driven divided by gallons used)?
thanks. |
#7 | |
![]() ![]() ![]() Drives: 2012 Yaris 3-door w/5-speed! Join Date: Nov 2011
Read my mind. Inquiring minds want to know! |
It was about 1-2 MPG off for me and my brother. Its close enough for me. I'll do a reset next time I fill up before work. I'll go back after work and refill up and we'll get a closer estimate of accuracy.
it wont be a very accurate comparison unless its done on a full tank of use.
Coasting gives you poorer mileage, compared to just letting off the throttle. The computer shuts the fuel flow off when throttle is zero, whereas coasting makes it think you are idling, thus burning a small amount of fuel.
I filled up again today I got 43.77 MPG on this tankful, the car is broke in I guess as it had 1398 on the ODO.
#14 | |
id guess you will be up around 44-46 mpg's in the spring when the air warms up and the regular gas blend is back in use. |
Only Timing Chains
Drives: 09YarisSedan, 94Truck22re Join Date: May 2011
I have an 09 sedan 5spd and at nearly 100% hwy averaging near the speed limit (70mph) I got 458miles on just over 10.5gallons. That's roughly 43.6mpg. No coasting. Again, cruising at near the speed limit the whole way with absolutely no attempt at fuel efficiency.
That being said over 40mpg should be easily achieved Last edited by NZ-FE Vios; 12-07-2011 at 05:05 PM. |
#16 | |
New mileage figure since last week. Filled up today 8.228 gallons vehicle has 1765 miles on it went 367 miles giving 44.60 MPG. It is still climbing. May hit 45 MPG next fill up.
![]() ![]() ![]() Drives: 2012 Grey Toyota Yaris SE Join Date: Dec 2011
Filled up today got 30.8 mpg for 327 miles. Not bad at all in fact i'm extremely happy! I had a 2008 Nissan Pathfinder that would've been 147 miles and for more money! My driving is a huge combination of city driving and highway driving. Chicago driving is a bisnitch! Haha!
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| New CAFE rules nearly double fuel economy by 2025 | digitalrain | Fuel Economy Forum | 27 | 02-24-2012 11:49 PM |
| 2012 Camry | Kal-El | Off-topic / Other Cars / Everything else Discussions | 26 | 10-02-2011 09:20 PM |
| Forced Induction and Fuel Economy | ellenbetty | Fuel Economy Forum | 11 | 08-13-2009 01:12 AM |
