Old 11-08-2012, 12:01 AM   #1
Meteorite_Marty
Drives: 2008 5-door Yaris Hatchback
Replacement Map Light Switch?
Seems my switch is burned out on one of the map lights. It isn't the bulb. Swapped good switch to the "bad" side and it worked.
Now I have to replace the bad switch. The little white switch is marked "MS-010A" and is Japan Miyama Miniature Pushbutton Switch MS-010A.
http://www.federalcomponent.com/pdf/MS-010.pdf
Does anyone know where I can source one of these, or an equivilant? Is there a Toyota part number for it? I don't want to replace the whole map light housing when only the switch is bad.
Meteorite_Marty is offline   Reply With Quote
Old 11-08-2012, 12:03 AM   #2
Meteorite_Marty
Old 11-08-2012, 12:27 AM   #3
Toyota only sells the entire fixture. Many parts like that switch are custom, making it hard to find them or an alternate. Your best bet is probably to find a replacement assembly from a junk yard.
Old 11-08-2012, 12:28 AM   #4
Meteorite_Marty
If this helps, the map light assembly is 81260-52030-b0
Just need the little white switch though.
Old 11-08-2012, 12:51 AM   #5
Meteorite_Marty
I was thinking that might be my only hope. Mine was replaced by the dealer 4 years ago. Time flies! I suppose the warranty on the part is 1-year?
Old 11-08-2012, 12:56 AM   #6
Meteorite_Marty
Seems like going rate is over $60.... yikes!!!!
Old 11-08-2012, 01:38 AM   #7
Meteorite_Marty
Anyone got a partially broken or damaged map light assembly lying around, and could extract a white switch from it? Let me know.
Old 11-12-2013, 09:00 PM   #8
chris johnson
Drives: toyota matrix
I had the same problem today. Toyota Canada only sells the entire assembly for $130. The manufacturer of the switch only sells in batches of 1000. So, I carefully dismantled the broken switch and re-assembled it, replaced it in the lesser-used housing, and it works! (for now)
chris johnson is offline   Reply With Quote
Old 11-12-2013, 11:18 PM   #9
yariseggvvti
Drives: Yaris Hatchieback
Try electrical store. They might have it. The best way is bring the old one with you and have them match one.
yariseggvvti is offline   Reply With Quote
Bulb Replacement Guide (led Sizes) theFEVA Cosmetic Modifications (Exterior/Interior) 113 02-28-2017 01:02 PM
What are you doing right now? Bob_VT Off-topic / Other Cars / Everything else Discussions 26819 12-31-2010 11:48 AM
OEM fog light switch question kustom play Cosmetic Modifications (Exterior/Interior) 10 01-02-2009 07:33 PM
how to change the Map Light "Front Light" k3nn4 DIY / Maintenance / Service 0 11-02-2008 01:06 AM
MAP LIGHT drell42 Cosmetic Modifications (Exterior/Interior) 2 05-21-2007 08:30 PM
