![]() Drives: 2007 Toyota Yaris Hatchback Join Date: Aug 2012
Reverse beep
Hi, I was unloading some things out of the car and I accidentally pulled off the little speaker that hangs down near the ceiling for the reverse beep. The wire isn't broken, just unplugged, but I can't see where it is supposed to plug into. Does anyone have a picture of where to connect it? Or is this not a standard item on the car? Thanks
That is not a standard thing. Chances are that it is wired to one of the two tail lights, so I would pop off the inside covers to see if you can find the connection point.
Mr. 155 and climbing
reverse beep speaker?
Yeah it makes a beep sound when I am about to back into an object.
Thanks for the info CTScott, I will try checking the tail lights later. |
![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
Reverse parking sensors, i dont think is factory option like Scott mentioned. If it's aftermarket, try to find the wire or ask previous owner.
| Rattle - Noise when Yaris put in Reverse | Jungle Rot | DIY / Maintenance / Service | 14 | 08-27-2015 06:32 AM |
| Help With Reverse Noise???? | JoshW | DIY / Maintenance / Service | 0 | 09-09-2011 12:27 PM |
| reverse gear..quick question.. | Yaris2910 | DIY / Maintenance / Service | 10 | 01-11-2011 05:14 AM |
| Toyota C160 Reverse Gear Problem | Parmas | DIY / Maintenance / Service | 2 | 12-01-2010 01:30 AM |
| Reverse gear crunch | Frankd1 | DIY / Maintenance / Service | 5 | 04-13-2009 12:43 PM |
