PO300
I have a 2000 ECHO with a PO300 error code.
Can someone advise what to check for? I looked it up and it sounds complicated. The vacuum lines all appear to be good.
![]() ![]() Drives: Yaris Sedan Join Date: Apr 2012
I believe the code was P0300, which states multiple misfire. Does your engine feel like it's running weird? Not smooth?
Runs normal. Mileage was down to 30 from ~34.
That is one of those codes that can have a bunch of causes:
- Open or short in engine wire harness - Connector connection - Vacuum hose connection - Ignition system - Injector - Fuel pressure - MAF meter - ECT sensor - Compression pressure - Valve clearance - Valve timing - PCV valve and hose - PCV hose connections - Air induction system - ECM
