Old 01-29-2015, 12:35 PM   #1
virgilio992
Drives: yaris now 1.0 12v
Super strange Transmission noise
Hello Folk! Sorry to bother you, but i'm experiencing a super-strange problem with my late 2010 Toyota Yaris 1KR-FE with 5 gears manual (yep, i'm european).
It's super hard to explain, that's why i will upload a video ASAP if requested. That's what's happening: when i reach an high number of revs (over 3500-4000 rpm) i hear a strange "cartoony" noise that disappears all by itself ( around 3-5s). Sometimes i hear it when i change gear but, most of the time, it's on the high revs. It doesn't happen all the times, but it's worrying! Personally i suspect a gearbox\transmission issue. My Toyota has 54 000 km (about 37 000 miles), it happens with ALL the gears except the 4th and 5th. I have NO problem inserting the gears, it's all fluid as usual. The problem started around december when i changed my brake fluid, coul be related? Hope you will help me sorting this out,
Andrew
virgilio992 is offline   Reply With Quote
Old 01-29-2015, 07:03 PM   #2
virgilio992
https://www.youtube.com/watch?v=eo94ID3kKnI
here's the video, you can hear it (it's not quite easy unfortunately) between 0:09 and 0:11.. it sounds like this https://www.youtube.com/watch?v=fan15rky1pg
please guys help me, i'm going nuts!!!
Old 01-29-2015, 07:33 PM   #3
It does sound odd. Are you sure it is the transmission and not the exhaust that is making the noise?
Old 01-29-2015, 07:42 PM   #4
virgilio992
mmmh i've never thought about it! How can i verify if it's my exhaust? It isn't a rattling sound by the way.....
Old 01-29-2015, 07:57 PM   #5
Rev the engine in neutral to see if you still hear the noise.
Old 01-29-2015, 08:03 PM   #6
virgilio992
it doesn't i noticed that i can hear the noise after a 20-30 mins driving it's hard to hear it before that amount of time! PS: can't go to a toyota dealership, it's more than an 100 miles away!
Old 01-29-2015, 08:16 PM   #7
It might not happen until it heats up. Once you start hearing the sound, then try the revving in neutral.
Old 01-29-2015, 08:22 PM   #8
virgilio992
i'll try tomorrow morning! (GMT +1 ! ) if it does the noise revving in neutral, what could be the solution? :\
Old 01-29-2015, 08:27 PM   #9
If it does it in neutral it could be a crack in the manifold or bad gasket between the manifold and exhaust.
Old 01-31-2015, 07:06 PM   #10
virgilio992
Ok i checked out and it DOES the noise revving in neutral! What can i do to fix this out? At least i think we can exclude a gearbox problem!
Old 01-31-2015, 07:30 PM   #11
That's good that it is not the gearbox. It is likely exhaust related, so now it is a matter of figuring out where it leaks when hot. You can try shining a light while someone else revs the car (once it is hot) or you can bring it to a shop where they can put it up on a lift to look from under.
Old 01-31-2015, 07:44 PM   #12
virgilio992
Thank you so much! I will try to shine a light with the help of a buddy of mine... unfortunately in italy it costs 50$ just to lift up your car..... i hope that the it would be cheap to solve it out
Old 01-31-2015, 09:30 PM   #13
If your remove the aluminum heat shield from the exhaust manifold you will be able so see better.
Out of curiosity, in what part of Italy are you located?
Old 02-01-2015, 07:26 AM   #14
virgilio992
I'll see ASAP!
i'm actually here:
Old 02-01-2015, 08:21 AM   #15
I'll see ASAP!
i'm actually here:
Ah, very good. I have never been that far south on the eastern side of Italy, except passing by there on a cruise ship.
Old 02-01-2015, 10:22 AM   #16
virgilio992
you should, the place is beautiful except for people's bad actitude
