Old 11-29-2014, 05:52 PM   #1
BoostedTRD
Drives: 09 Yaris Hatchback
Boostedtrd turbo log!!
I received my 1NZFE a few weeks ago got it for $250 and it was manual with 90K and now it's time to take apart. This build will take some time so bare with me. I will finish taking it apart tomorrow.
BoostedTRD is offline   Reply With Quote
Old 11-29-2014, 06:43 PM   #2
LTHatch
Drives: 2013 Yaris Hatchback L
Fantastic! Please take tons of pictures my good sir!
LTHatch is offline   Reply With Quote
Old 11-29-2014, 07:24 PM   #3
BoostedTRD
Will do!!!
Old 11-30-2014, 09:11 PM   #4
BoostedTRD
So I finished taking the engine apart. I will send it to the machine shop sometime this week.
Old 12-02-2014, 05:21 AM   #5
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Sweet. I love build threads..
I may have missed it in another thread. Whats the plans for this one?
-Derrick-
Old 12-02-2014, 10:18 AM   #6
BoostedTRD
I am glad you asked My HP Goals are 300+
Build Plans:
Head:
-Port & Polish
-Supertech Scion TC valve springs and retainers (good results according to Blown_xa)
-Stock Valves since I can seem to find anyone that makes over sized valves
- Golden Eagle intake manifold with 1zz Throttle body
Block
-CP Pistons 9.5:1
-BC Rods
-ARP Head Studs
-Factory Head Gasket
-Factory Main Bearings.
-Factory Rod Bearings.
-Factory Thrust Bearings.
-OEM Rear Main Seal.
Fueling-
Golden Eagle Fuel Rail with Fuel Pressure regulator
Walbro 255 Fuel pump
Denso 550cc injectors
whatever else I need to make the fuel return system
Clutch
-ACT 6 Puck Clutch
Exhaust
-Custom
Tuning
-Will be done by Ptuning since they tune Blown_xa car and he was tuned with Haltech sprint 500 and that's what I have.
Old 12-02-2014, 12:47 PM   #7
ilikerice
ilikerice's Avatar
http://www.yarisworld.com/forums/sho...ghlight=valves
I know these were sold already, but did you check this company out?
I could have sworn Garm had some up in his online store before. Have you talked to him also? Maybe he knows someone.. worth a shot if not being able to find them is the issue and money isn't.
-Derrick-
Old 12-02-2014, 01:46 PM   #8
BoostedTRD
Thanks for this. I will ask to see if they have them in stock and to see how much of a difference will make to justify the $400.
Old 12-02-2014, 08:48 PM   #9
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
looks good man. When it comes time to assemble the motor I will give you a heads up about a couple things. Those ARP head studs will require small modification to a couple of things for fitment
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 12-02-2014, 08:55 PM   #10
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
won't you need to do some machining to accommodate larger valves if you do decide to go that route anyway? I'd assume a larger valve will require a larger diameter port and larger seat to work effectively.
Old 12-03-2014, 10:01 AM   #11
BoostedTRD
Thanks bro, I really appreciate your help with my build. Mad props to you
Old 12-03-2014, 10:02 AM   #12
BoostedTRD
Yup your right, I don't if its even worth the time and money to get larger valves installed, unless they give you some sick hp gains.
Old 01-31-2015, 03:57 PM   #13
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
So many builds start off great then go silent, I will admit that I'm guilty of this too
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
Old 02-02-2015, 02:08 PM   #14
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
time for this kind of stuff is always a factor as well as getting pictures moved and hosted, etc. posting progress is time consuming as well. hopefully we will see more on this soon as I enjoy them myself. I will be curious about the turbo setup and exhaust manifold choice.
Yoda's Turbo Log Yoda Forced Induction Forum 404 08-17-2013 08:22 PM
FS : GT2560R Turbo + Manifold Parmas Items for Sale by private party 0 08-24-2012 09:35 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-10-2012 12:35 AM
curious about micro image log type turbo manifold ! jenfre Forced Induction Forum 9 10-18-2010 11:41 PM
