Old 08-27-2012, 09:16 PM   #1
spin_king
Drives: 03' 1.5 vitz rs
Question sway bar & endlink
Can I change my sway bar & endlink bushings myself? What's the steps & difficulty leevel
spin_king is offline   Reply With Quote
Old 08-30-2012, 01:29 AM   #2
CoryM
Drives: 2009 5-door, 5-speed
Endlinks in theory are not too hard. Two nuts on either side. However, they often seize and for the inexperienced this can be difficult to deal with. Often comes down to cutting them off. The swaybar itself is buried and it's not likely you will want to do it yourself. Pretty sure the subframe has to come out to do it, but haven't looked too close.
If you have a cut-off tool I wouldn't hesitate to try the endlinks. Worst case scenario you have the cut the endlink bolts off.
Cheers.
Old 08-30-2012, 02:27 AM   #3
End links are easy, and we sell adjustable high grade ones for the Yaris.
The sub-frame has to be partially dropped to snake a front sway bar in there -- the rear sway bar is very easy.
Tags
end link, sway bar
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 06:25 AM
My Ultra Racing rear sway bar install CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 49 03-03-2011 03:08 AM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 07:07 AM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 12:52 PM
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 02:05 PM
