EcoFriendly
Drives: 2007 Vitz HB Join Date: Sep 2012
A/C Compressor
I looked in the manual and I didnt find anything that is related to an AC clutch + pulley assembly.
Does anyone know if the AC compressor has a clutch assembly that can be changed? I also tried looking for toyota OEM parts and I didnt see anything. I am wondering if the bearing and clutch assembly of the AC compressor is one unit that is not maintainable by DIY parts. |
For whatever reason they are not purchasable as separate parts. IT appears that you could definitely remove the clutch/pulley, but then you can't purchase a replacement.
| a/c compressor relay unit?? | marcus | DIY / Maintenance / Service | 31 | 08-27-2013 02:25 PM |
| A/C compressor | yaryar83 | General Yaris / Vitz Discussion | 3 | 06-03-2012 10:47 PM |
| A/C COMPRESSOR BEARING | blacks | DIY / Maintenance / Service | 1 | 10-27-2011 09:45 AM |
| A/C compressor - Always on | barryware | DIY / Maintenance / Service | 7 | 02-20-2011 12:10 AM |
| What determines the duty cycle of the A/C compressor? | LtNoogie | General Yaris / Vitz Discussion | 43 | 08-07-2010 12:46 PM |
