Old 04-22-2011, 07:25 PM   #1
seth_man
seth_man's Avatar
Drives: 08 Liftback
Big Brake Kit Discovery
well i had some extra time at the shop and decided to try something out just for s&g's. i discovered that the AEM big brake kit for civics BOLTS ON to the yaris. NO Cutting, Drilling, Cursing or Modifying to bolt them on. 12" rotors and they fit under my 16" wheels. i did have to clearance the front top of my caliper .010" or so to have a little clearance for my stick on wheel weights.
What you will need:
1. 7mm Spacer to go between Stock Yaris caliper bracket and caliper extension bracket that comes with the brake kit
2. Longer Bolts I used 12mmx1.25mmx50mm bolts instead of the stock caliper bracket bolts
3. Nothing else
seth_man is offline   Reply With Quote
Old 04-22-2011, 07:41 PM   #2
wildmongoose26
wildmongoose26's Avatar
Drives: 09 5dr Yaris
What all is included in said kit? The bracket for the caliper and the rotor and thats it?
Brent
Old 04-22-2011, 07:45 PM   #3
seth_man
seth_man's Avatar
Drives: 08 Liftback
yeah, rotor, bracket, a few bolts
Old 04-22-2011, 10:48 PM   #4
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
So, how much better is the braking with a bigger rotor and stock caliper?
Old 04-22-2011, 11:08 PM   #5
^ good question. You have the same caliper/pad operating on a rotor that is now spinning faster. Braking might be worse, not better. It will definitely be hotter.
Overall though, very neat idea.
Old 04-23-2011, 12:38 AM   #6
krusty
krusty's Avatar
Drives: 2010 Yaris ce
How would the rotor be turning faster with a bigger diameter rotor?
krusty is offline   Reply With Quote
Old 04-23-2011, 07:45 AM   #7
seth_man
seth_man's Avatar
Drives: 08 Liftback
well first track day will be next sunday so i will find out. feels pretty good driving around town though.
Originally Posted by Spahrticus View Post
I just see stock pads being chewed up...
some hawk pads are on the way
Old 04-22-2011, 11:48 PM   #8
yaris2010RS
yaris2010RS's Avatar
very nice...... this seems like a less expensive way to get a bigger brake look on aftermarket rims....
if only have a rear disk kit with less work....
Old 04-23-2011, 02:04 AM   #9
If you think about it, at the perimeter, a larger diameter "circle" has to travel faster to achieve one revolution as a smaller circle. The outside of a larger rotor is where the pad contacts it. I'm armchair discussing here, but I do know the friction would be greater to slow the velocity, causing more heat.
And all of that might not make a huge difference. Let's hear the OP's review!
Old 04-23-2011, 08:11 AM   #10
That's true, but it's my understanding that the main advantage of larger rotors is to have more mass and surface area to dissipate heat from braking, so the temperature increase you mentioned may be canceled out.... food for thought! (and google searches )
Old 04-23-2011, 01:35 PM   #11
cfeng
Drives: Yaris 2010 Liftback
There are considerations necessary for matching a brake pad to a rotor. Usually, the inner diameter of the surface that the pad touches is 58% of the outer diameter, in order to achieve greatest braking torque.
cfeng is offline   Reply With Quote
Old 04-23-2011, 05:44 AM   #12
Spahrticus
Spahrticus's Avatar
Drives: ///M3, Yaris
Spahrticus is offline   Reply With Quote
Old 04-23-2011, 09:58 AM   #13
Lil Abner
Drives: 2009 3dr LB Manual
You will still have the same angular velocity (rpms), but the tangential velocity at the outer diameter IS bigger (faster). However, you need to look at the main benefit of this system. The larger diameter of the rotor, and the pad being further away from the center INCREASES the torque the brakes can apply. Torque equals F X D (force times distance). So you should notice an improvement. As far as heat, I don't see that as a problem. Sure, aftermarket pads will help, but the stocks should work for now (unless you track the car).
Old 04-23-2011, 10:18 AM   #14
Kongo-Otto
Drives: '09 Yaris & '10 Auris
Centering the disc should be done by the hub not by bolts. And of course i would never modifiy a brake caliper this way.
Atleast in Europe that kind of engineering is strictly forbidden.
Old 04-23-2011, 10:21 AM   #15
Lil Abner
That's a good point. I didn't see that when I first looked. Some rings to center the rotor might be a smart thing to do.
Old 04-23-2011, 06:24 PM   #16
RedRide
RedRide's Avatar
Consided a caliper brake on a bicycle.
You need relatively little caliper pressure on the rim as compared to the pressure you would need if it was close to the hub.
It's just basic physics.
Old 04-23-2011, 10:19 PM   #17
wildcard
wildcard's Avatar
Drives: 09 3dr HB 5sp
This thread haz revolutions...
wildcard is offline   Reply With Quote
Old 04-24-2011, 12:35 AM   #18
Lil Abner
Yeah, that's what I posted earlier about the angular velocity compared to the linear at the rotor edge.
I'm sure the OP is wondering what happened to his thread. :-)
one brake light out xartrax DIY / Maintenance / Service 3 01-27-2011 12:40 PM
big brake kit turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-13-2007 01:44 PM
big brake kit yrsdrgn Performance Modifications 17 02-20-2007 11:05 PM
cheap trd big brake kit *joke* birdy Off-topic / Other Cars / Everything else Discussions 3 06-13-2006 12:04 AM
