![]() Drives: 2010 Yaris LB Join Date: Jan 2011
Waddle getting old
Ok, so I'm finally fed up and I need the help of those who know. I bought my 2010 Yaris new with 40 miles on it. It currently has over 30k.
The one thing that I've noticed from the beginning is a slow speed waddle in the front end. Basically, the front seems to move a bit from side to side. (Feels like it's coming from the passenger side) The steering wheel has no movement when this occurs. At higher speeds, +10MPH, it goes away completely. Most of my driving is freeway, so I've just tried to ignore it. It is a very similar feel to a broken belt in a tire. I inspected the tires when I did my rotation and saw nothing out of the ordinary. I also checked for bearing play while the front wheels were off the ground, felt fine. After the rotation, the waddle was still there. So, I either have two, equally damaged tires or there's something else wrong. I'm on the factory Goodyears. The only other problem I can think of is that my brake rotors seemed to come pre-warped with the car. It's not really noticeable unless I'm doing a lot of braking, which isn't often. I can't think of any other issues. Alignment has always seemed spot on. I don't have a garage to work in, so the more focused the troubleshooting, the better. Thanks in advance!
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
Sounds like a bent wheel or a crappy tire (that has a flat spot where the belts overlap).
That's what I was thinking to, except it's exactly the same after rotating the tires from back to front. I guess it is possible to have more than one damaged tire. I know the factory tires don't have the best reviews.
I know for a fact that factory tires (Bridgestone Potenzas) suck pretty badly.
You could try rotating your wheels to see if your situation changes at all. Cheap and easy to do.
The other thing to try is pulling the EPS fuse and taking a drive to see if it is actually that the electric power steering is out of calibration.
Thanks Scott. I'll try to find that fuse and see what happens.
