Old 04-29-2012, 07:44 PM   #1
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Limits of stock 1nzfe found once and for all.
This is my motor with bent rod and cracked block and piston sleeve. This was at 12psi and 197whp dynoed only 2 days before major engine noise on a mustang dyno. Now on to the build of my junk jard motor.
pimp my yaris is offline   Reply With Quote
Old 04-29-2012, 08:19 PM   #2
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
Ouch
Originally Posted by sw07gt
Old 04-29-2012, 10:58 PM   #3
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Told ya the rods where the first to go lol. Thanks to for getting that Dyno. Be sure to add your info to my durability thread when u get a chance. You pushed it further than i did by 2 psi. At 10psi after awhile I burnt up my valves. How are yours?
Old 04-30-2012, 01:55 AM   #4
Focus_Sh1ft
Focus_Sh1ft's Avatar
Wow. I'll keep the innuendos to myself.
Looking forward to watching your rebuild. Thanks again - this is a vital piece of information for those of us with boost.
Old 04-30-2012, 02:17 AM   #5
hmmm Gonzo rods :D Sorry to hear that dude, but now we have a better idea of the limitations of the stock hardware :)
Old 04-30-2012, 07:14 AM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
It has become obvious that 8psi is the max safe boost level with considerations of even staying at 6 for those folks that are looking for longevity and reliability. Personally in hindsight with my build I wouldn't tell anyone to use an internal wastegate unless they installed a premium turbo. I would also sttrongly recommend performing a compression test before and then again after installation.
Old 04-30-2012, 07:17 AM   #7
fnkngrv
fnkngrv's Avatar
I wish that I could reinforce your results, but since I had spiked to over 25psi the couple times my situation isn't a good marker. I will enjoy tearing my motor down especially since my rods shattered.
Old 04-30-2012, 07:54 AM   #8
Did you post the dyno chart from your mustang run?
Old 04-30-2012, 12:04 PM   #9
johnny_vitz
Drives: 2005 Toyota Echo
I'm still wondering if there is a difference in the bottom end of the echo/xb compared to the yaris. Blownxa said he went through a few engines just above 150whp in his xa (with a good/safe tune) as well as a couple other xb guys on clubxb.com
Sorry to hear about your engine pimp. How much boost will you be running once it is built?
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 04-30-2012, 12:38 PM   #10
^ They seem identical to me. I've reviewed them side by side. Don't know about part numbers.
Old 04-30-2012, 12:47 PM   #11
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
thats some high boost for these little guys. Now to the build. Good Luck!
Old 04-30-2012, 12:59 PM   #12
Looking at the EPC, the Echo, xA, xB, and Yaris all share the same part numbers for pistons, rods, and crankshaft. The Prius uses the same rods, but different pistons and crankshaft.
Old 04-30-2012, 01:32 PM   #13
fnkngrv
fnkngrv's Avatar
The rods are useless unfortunately. I totally underatand why they are what they are, but it still is a fact.
Old 04-30-2012, 01:40 PM   #14
It would be very interesting to have one of the stock rods analyzed for its real rating. From what I have been reading in some automotive engineering journals, stock rods are typically designed to handle between 25% and 40% more force than stock, which in our case would mean about 150 HP max (if ours are really 40% over engineered).
If we could find out the compression PSI limit of the stock rods, it would be easy enough to run the math to determine the theoretical boost limit.
Old 04-30-2012, 01:50 PM   #15
Crashy would cowering in fear if she could read that post :D
Old 04-30-2012, 07:38 PM   #16
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I wouldn't tag a certain amount of boost to the limitation of stock rods.... It is power. Most likely the onset of power (torque) is the best measurement of limitation.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 04-30-2012, 08:41 PM   #17
True, although it is the instantaneous force of the combustion explosion pushing against the crank before the rotation occurs that does the damage, as that peak force can be in excess of 6000 lbs. That force is the pressure within the cylinder at combustion multiplied by the area of the piston and by the sine of the angle of the rod at TDC (which is about 10 degrees). So, if that force peaks high enough either the bearing or rod will fail.
Old 04-30-2012, 08:42 PM   #18
Yoda
Yoda's Avatar
^^this
