![]() ![]() ![]() Drives: MR2 Spyd/Type R/Yaris/Civic Si Join Date: Feb 2007
Its hard to see in the photos, but because of the location of the O2 sensor bung on the DC sports header, the backside of one of the bolts attaching the header to the downpipe is going to contact the O2 Sensor. I've attached two photos. 1 is unedited (to show the original) 1 is edited with Green and Red circles to show the following. The bolt holding the downpipe to the header (circled green) is almost fully seated and not hitting anything. The other bolt (circled red) is just sitting there in its hole, but if I thread it even 2 or 3 turns its going to be pushing on the O2 sensor (not good) If I tighten the bolt (circled Red) all the way like its supposed to be, it will certainly make a huge impact into the O2 sensor Anyone else run into this? After struggling for quite sometime to get the old header off / replace the factory header hardware with the ARP stuff (also from Microimage) I'm kinda at a loss as to how to proceed. Help >>>>>>>>>>>>>>>>>>>>> ![]() ![]() Will |
There was someone else either on here or on the MI forum that had the same issue. If I remember correctly the solution was sending it back for a replacement.
Check this thread. http://www.yarisworld.com/forums/sho...header+problem
His issue was not putting the gasket on. Looks like yours is on, but did you check? |
0-60 in slow
Make sure you're not using the bolts from the muffler.
play every day
![]() ![]() Drives: 07 Yaris Join Date: Sep 2012
what about if you remove the o2 sensor and flip that one bolt so the head is against it?
That looks like the older, defective DC Sports design, where the O2 sensor bung was incorrectly placed. They have corrected that issue.
#9 | |
Thanks! |
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
If you bought it from Garm I doubt you will have a problem. I bought mine from him a couple years ago. Once I put that gasket thing back in, it worked fine.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
I had that problem, but for me it was due to forgetting to put that little gasket between the header and the midpipe.
![]() ![]() ![]() ![]() ![]() Drives: Toyota Yaris Sedan 09 STD Join Date: May 2009
Cut the tip of the bolt and problem fixed! lol
play every day
#15 | |||||
I haven't been anywhere near the muffler yet Quote:
I guess the pictures don't do it justice, the O2 sensor is almost rubbing on the flange as is / I'd have to cut almost all the thread off the bolt |
#16 | |
Another option would be to weld a new bung in a better location for the O2 sensor and plug the existing hole.
#17 | |
I paid $250 ish and I find the Weapon R for about $230 ish / not sure why I went DC sports in the first place? I am totally considering that!, only problem is it would most likely read off just one cylinder (although I think I've read about others that had a similar setup and didn't experience any drawbacks) |
I'd go without the header for the show (put the factory one back on) and send it back. The longer you keep it, the harder warranty stuff will be.
I am actually a big fan of the Weapon-R (I has one) and would recommend it. There is also a huge price premium between the two... and I haven't heard of any issues with them. |
| A day out with mechanic went wrong- Right arm problem | talhahs | DIY / Maintenance / Service | 6 | 05-17-2013 05:20 PM |
| Megan Header Install [pics] | Chris07LB | Performance Modifications | 132 | 09-29-2010 03:41 PM |
| DC sports header installed. | largeorangefont | Performance Modifications | 41 | 09-20-2007 09:14 PM |
| Weapon-R Header (4-2-1) | CASTREX | Performance Modifications | 28 | 02-19-2007 01:57 PM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 09:12 PM |
