![]() ![]() ![]() Drives: 2004 Echo HB Join Date: Oct 2008
Auto vrs Manual engine
Does anyone know if the auto equipped engine has the provision for the pilot bearing required for a manual transmission ? I have a line on a newer motor but its an auto. If it doesn't have the provision it won't work. Please let me know.
There is no difference between a block that comes out of a MT car versus an AT car.
I was referring to the crankshaft pilot bearing.
Everything up to and including the flywheel is the same for both. You can either bolt the torque converter to it or the clutch to it.
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
or throw in the third option and attach a generator to it and have it power cells and then use the cells to power electric motors and call it the little engine that can. :D
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
WOW that would be worth knowing except for the fact Im unlikely to put 100k miles on my Yaris in the next 30 years.
Hopefully I wont need another engine!
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| 1kr-fe engine wiring | boothybunch | DIY / Maintenance / Service | 0 | 03-28-2011 03:59 AM |
| two questions (relating to manual vs. auto) | osmoq | New YARIS Purchase Forum | 0 | 05-19-2010 05:40 PM |
| Manual vs. Auto Transmission | j996tt | General Yaris / Vitz Discussion | 30 | 02-25-2010 12:43 AM |
| Handbrake question (Manual vs. Auto) | Chaad32 | General Yaris / Vitz Discussion | 31 | 07-30-2006 07:03 AM |
