My Face Is Ridiculous
Drives: 2010 Toyota Yaris 3dr LB Join Date: Dec 2011
Most N/A power?
Who's putting down the most N/A power and is there a dyno sheet showing it? Just curious.
This is an interesting one....
I know that garm has said that with certain bolt-ons, he got 105 at the wheels and he has a dyno sheet to prove that. I also know that if you have the green, you can go with higher compression pistons and get more power out of your N/A yaris. there has also been talk of head work and cams. I don't know if anyone has done all that and had it dynoed too. I would like to get mine dynoed though I have no baseline to compare it to. I think I should be around the 105-110 range which isn't bad. |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
This is mine before cams and head work. The current numbers are private.
![]() http://www.yarisworld.com/forums/sho...&postcount=132
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
Only Happy When it Rains
i'd be surprised if anyone has more, although technically you probably could since Jason@SportsCar has to worry about staying in class.
Colin Chapman disciple |
A MI intake, new pistons and some bigger valves would crush it.
0-60 in slow
Drives: light blue liftback Join Date: Aug 2009
Yeah I'm 6hp or do below Jason with long tubes, a filter, and pulley. I'm sure I could get another 6-15hp with a cai and tune.
There is lots of power left on the table if you know where to look. http://www.yarisworld.com/forums/sho...&postcount=168 |
I'd like my tq around 130 ft/lbs or so. I couldn't care less about hp. lol
#8 | |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
![]() ![]() This is how it ran on the dyno: tooter intake manifold 1ZZ throttle body SRI + BLOX velocity stack + dry element filter Weapon R 4-2-1 exhaust header all of the stock exhaust cats Micro Image center exit axle back exhaust Stock ECU No tuning regular unleaded 87 octane gas Basically just the easy bolt on mods. |
| kuro-kuro, mga sarisaring katanungan | xtremist | Middle East | 2740 | 01-27-2020 03:36 AM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| Yaris Verso: Reset power window jam protection | togo | DIY / Maintenance / Service | 3 | 01-10-2013 10:03 AM |
| DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS | julienrl | DIY / Maintenance / Service | 1 | 08-31-2009 10:06 AM |
