![]() Drives: 2007 yaris sedan Join Date: Jul 2011
overdrive
I have a 2007 Yaris sedan with 140,000 miles it has an automatic transmission. My question is that no matter what the outside temp. is here in Louisiana it does not like to shift into overdrive in the morning(worse) or started after 8 hours of rest. I am certain that this has became noticeably different than the previous years. Is there something I should have checked? a/t oil never changed
1.5L
Drives: 2009 Yaris Join Date: Apr 2012
This is same as my Yaris with 72k miles on it and on my other yaris with 38k miles. It seems like the computer is programmed so that the engine warms up as fast as possible to reach its normal operating temp to save fuel.
could the thermostat be stuck open?
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
the light on your dash goes out at 130 degrees Fahrenheit, normal operating temperatures for internal combustion engine are between 178-215(don't remember exact but around there). our little 1nz-fe appears to go from 184-204(at least that is what my gauge reads) the priority in today's vehicle is emissions first, so the engine has to get warm enough to burn of more toxic gasses. the engine will make that it's priority before it makes fuel economy a priority (i.e. Overdrive) so it is fairly common any more for features to not be available until the priority list is checked off.
oh the 130 should be when the computer takes over full control because the Oxygen sensor is warmed up.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
Both the water temp and AT Fluid temp need to reach a threshold before 4th gear prohibition is disabled. I did some experimentation a while back and figured out how to override it with a momentary switch and resistor. It works perfectly and is very simple to implement:
www.yarisworld.com/forums/showthread.php?t=37691
Nothing beats a Toyota!
Drives: 2013 Yaris 5 dr liftback Join Date: Jan 2009
When I first got my Yaris, I was concerned but after reading about the systemic process on this forum, I just got used to it.
I don't think I possess the mechanical skills to try and override anything so I will leave it along and just keep on truckin!
Big Dave Indianapolis, IN Synthetic Oil....its in my car.....for at least 10,000 miles! ![]()
![]() Drives: Corolla Join Date: Sep 2009
Normal operation. My inlaw's Yaris & my old Echo do the same exact thing.
2003 Echo - Auto Trans - 93,000 mi. |
| Transmission shifts hard from 3rd to Overdrive ... | Hershey | DIY / Maintenance / Service | 4 | 07-25-2012 12:30 AM |
| FS: NST 20% Overdrive Alternator Pulley | MGargano | Items for Sale by private party | 12 | 06-05-2011 11:06 AM |
| FS: 2009 Alternator & Overdrive Alt. Pulley | MGargano | Items for Sale by private party | 9 | 10-28-2010 07:42 AM |
| How would you rate the auto trans in the Yaris? | detroiter | General Yaris / Vitz Discussion | 39 | 08-11-2009 05:08 PM |
