![]() ![]() ![]() ![]() Drives: 2010 Yaris S Join Date: Apr 2010
Any rear shocks out there interchangeable with Yaris?
Hey all,
I have a set of 150 mm rear springs and don't want to resort to zip ties etc, anyone know of a shorter length rear shock that will work with the yaris? I.E- 07-08 Honda Fit? Older bmw's etc. Thanks in advance
"In his heart a man plans his course, but the Lord determines his steps." Proverbs 16:9 |
Form>Function
e46 fits
you still messing with those dampers? the Yaris ones might be longer but mine handle 130mm springs just fine for 8-10 months thus far |
are the e46 ones shorter than the yaris?
![]() ![]() ![]() Drives: 2010 Yaris HB Blazin' Blue Join Date: Feb 2011
Check with Micro Image about the Tokico HTS rear shocks, in most applications they are shorter than stock.
http://shop.microimageonline.com/Tok...ks-HTS-116.htm racerb
racerb '86 Celica GT '87 Celica GT-S '98 Rav4L '01 Tundra SR5 |
Buy the rear shocks out of any decent coilover kit and you can adjust the travel for shorter springs. Megan, for example.
Expert
Drives: Toyota Yaris Join Date: Jun 2013
As per my knowledge e46 are not shorter than the Yaris so better bring the vehicle to any car care center they will give you a better advice and will fix it immediately.
car service Brisbane |
Problem, officer?
Drives: '06 Yaris 5DLB 1.5 Join Date: Oct 2010
Will fitting E46 rear shocks offer any benefits?
i.e. better comfort, handling, etc.? I can source them (OEM Sachs Super Touring) dirt cheap here. And will there be any disadvantages when paired with front stock struts? Thanks!
Quick update, received the e46 rear shock from Megan it is identical to the yaris shock despite the fact Megan website says the e46 shock is 170mm in length and yaris is 250mm
Form>Function
LOL yea they probably mean the e46 is 170mm in length and the yaris damper can adjust from 170mm to 250mm lol
the e46 damper doesnt adjust like the Yaris? Return it to them |
ive been running function form type 2 e46 rear shocks for a while now, the higher rate valving is great if your going to go with stiffer springs than the megan shocks will allow you. right now im running 500lb springs in the rear and the car rotates awsome around the cones while never really losing grip like the standard megans even on the highest setting.
Sethman: The issue is I have a 150 mm spring that I am trying to use, and even on the lowest setting the megan shock is too long and doesn't hold the spring in place when the suspension is unloaded. I am looking for a shorter shock that can hold the spring in place, are the function and form coilovers able to go lower than the megans?
Form>Function
why does that bother you so much? I run 130mm springs on the normal megan struts without any problem, nothing has ever popped out and the suspension works perfectly. The damper slows the descent and release of tension so slowly that you shouldnt ever have a damper fully extended and the spring sitting unweighted. Are you offroading or something?
#13 | |
If you can point to a real life Yaris spring falling out, I'll be very surprised.
#14 | |
With my swaybar going uo steep angle driveways I get 3 wheel motion which is what is prompting me to be concerned about the spring falling out. 1.5 are you using a rear swaybar?
Form>Function
Yes I am running the UR 19mm
The 3 wheel motion is actually what Garm and I are referring to as the reason NOT to worry. Your car only allows 3 wheels to touch the ground because the damper is doing its job and slowing the descent of the spring and valve so much that the wheel is partially off the ground, that same process is keeping the spring pretty much taught under the weight of the car, yes if your car remains suspended for some time then eventually the weight of the car may cause the damper to fully extend, but again, when would you be in the air for long periods of time unless jacking up the car or jumping ramps? |
I guarantee you I'm using shorter, stiffer springs than any of you (10k rear) and I can't imagine one falling out. My car 3-wheels in autocross; no issues.
Nor can anyone give an example of one falling out (see post #13).
Form>Function
Dang shorter than 130??? Crazy. I want some ~150-180mm 10k for my fronts
| 2006-2011 Yaris Liftback Intermittent Rear Wipe Module | CTScott | Items for Sale by private party | 5 | 12-28-2011 11:28 AM |
| Previous gen Echo shocks on current gen Yaris | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 02-28-2009 12:47 AM |
