Old 01-24-2013, 03:12 AM   #1
yarispe
Drives: yaris 2008
power steering failing
In two occasions while parking the steering lost power momentarily. Then in one other occasion when stopped at a red light it happened again.
The mechanic says it's a battery problem and needs to be replaced.
My question is: Will I be able to steer the car manually if the power steering dies?
I wonder if without power steering the wheels might be locked.
BTW this is a Yaris 2008 with auto transmission.
yarispe is offline   Reply With Quote
Old 01-24-2013, 07:25 AM   #2
The power steering is just an assist, so you can still steer if it stops working.
The primary reason why it turns off is overheating. The Power Steering ECU gets hot as it drives the electric motor, and the more that you turn the wheel at low speed the hotter it gets. Once it reaches a specific temperature inside of the ECU it temporarily shuts off.
When yours cuts out does the PS light come on on the cluster?
Old 01-25-2013, 06:15 PM   #3
yarispe
Drives: yaris 2008
I noticed the PS light on once but can't say it didn't come on the other times as I wasn't paying attention.
They replaced the battery... and so far so good.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
Power Steering Light sıɹɐʎ DIY / Maintenance / Service 12 02-19-2014 08:22 PM
power steering off jonhy_ sm DIY / Maintenance / Service 13 09-12-2012 12:02 AM
DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS julienrl DIY / Maintenance / Service 1 08-31-2009 11:06 AM
FREE Sciontech power steering resivoire cap YarisSedan Items for Sale by private party 3 04-27-2009 10:40 AM
