Old 01-28-2013, 08:44 AM   #1
my2sense
Drives: 2007 Red 5dr RS
Wheels spin while in neutral
Hey everyone, I observed the strangest thing today. I was doing an oil change and had the front jacked up. After finishing the change, I started up the car to let the oil circulate and both front wheels started spinning while my car was in neutral!
I can easily stop the spin with my hand/fingers but it will start spinning again when I let go off the wheel. It is related to engine speed and will rotate faster if I blip the throttle. Depressing the clutch stops the spin as expected.
Since the car is not in gear, how is it spinning? Anyone has any ideas?
Thanks
my2sense is offline   Reply With Quote
Old 01-28-2013, 08:48 AM   #2
seth_man
seth_man's Avatar
Drives: 08 Liftback
even though its in neutral, when the clutch is not engaged the input shaft is spinning, its just because there is some light resistance between parts inside the trans. perfectly normal
seth_man is offline   Reply With Quote
Old 01-28-2013, 03:49 PM   #3
jcboy
Drives: Sedan 07
perfectly normal, including the the clutch part--it should actually stop it from spinning. the spinning is, correct, a light resistance.
Old 01-28-2013, 04:16 PM   #4
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
it was just so happy that it had fresh oil that it wanted to go for a ride :D
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Old 01-29-2013, 08:39 AM   #5
my2sense
Thanks everyone for the info. Never saw that happening on my other cars before.
12/20/08 Buddy Club USA 5th Anniversary Clearance SALE DuckinOut California 3 12-18-2008 01:25 AM
forged rims Vs. alloys red-jdm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-23-2007 09:30 PM
Feedback on these wheels BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-04-2007 09:09 PM
