![]() ![]() Drives: 2011 Toyota Yaris Join Date: Jan 2011
Accessing Tail Lightbulbs
I'm sorry, but I did a search and just couldnt find pictures of how to access the lightbulbs in my hatchback lights. Does anyone have a link to where I can see how to access my backup lightbulbs?
Thanks in advance.
There is a plastic piece that pops off on either side to give you access. Once you remove it you will see the bulb sockets, which you twist to remove. The back-up light is the bottom one.
Thanks!
#4 | |
Drives: yaris Join Date: Feb 2013
replacing reverse light
I've twisted the socket but it only moves about 1/8 turn and will not extract when I pull it.I'm nervous about using pliers or screwdriver to lever it in case the plastic breaks. cheers |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
oh just use your fingers to twist it. IIRC it twists CCW when removing (CW to put back in)
Pliers or any other item will damage the tabs. |
| Installing Trailer Light Harness | vandallen | DIY / Maintenance / Service | 7 | 06-10-2024 10:06 AM |
| LED tail lights installed | Cutie Pie #2 | Cosmetic Modifications (Exterior/Interior) | 10 | 08-20-2012 11:25 PM |
| Original tail light without rear fog light for Yaris 3dr 2009-2011 | Ot_tO | Cosmetic Modifications (Exterior/Interior) | 9 | 08-07-2012 04:27 PM |
| Tail lights for 09 sedan | piepie | Cosmetic Modifications (Exterior/Interior) | 7 | 06-03-2009 09:24 AM |
| FS: Yaris Liftback Tail Lights Stock OEM | tekmoe | Items for Sale by private party | 5 | 06-15-2007 11:57 PM |
