Old 02-18-2013, 06:45 AM   #1
ShowPhur
ShowPhur's Avatar
Drives: 2007 Yaris LiftBack
Quick Question : Lowering
Hey all,
Just got new rims(check my profile). i wanted to know if I want to lower it 3inches will I need coilovers, or can I just have lowering springs installed with new shocks?
Thanks all
ShowPhur is offline   Reply With Quote
Old 02-18-2013, 09:36 AM   #2
vten
Coilover for sure.
Checks for the lowest drop from one brand to another, as they also have a different spring rates .
Good luck
Old 02-18-2013, 09:58 AM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
if it is all about looks, you could also go air.
Colin Chapman disciple
Old 02-18-2013, 10:34 AM   #4
Yarflana
Drives: 2008 Base Model
Originally Posted by ShowPhur View Post
Hey all,
Thanks all
rims are nice!
Yarflana is offline   Reply With Quote
Old 02-19-2013, 12:41 AM   #5
ShowPhur
ShowPhur's Avatar
Air is a bit pricey is AUS, i'm thinking coilovers:) thanks for the replys so far. Much appriciated
Old 02-19-2013, 01:57 AM   #6
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Let me share my experiences. First you should understand what spring rating means.
For instance, 4k Rating means for each 4 kilogram the spring will compress 1 millimeter, or ~224lb/inch. From there you can start seeing what rating you will need at what spring free length to get your desired drop.
Im on 8K with 7" free length before compression. With the weight in the rear, the spring compresses just about an inch. With 4K it would drop 2 inches.
I can tell you that i am 1 collar ring away from being as low as i can with that particular spring. I would recommend getting a shorter spring when you go up in stiffness.
Measuring from bottom of my 14' rim to top of fender my rears are at 20 1/16". Front at 19 7/8"
Check out my Build thread:
Lowering spring question? ijose 845 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 03-18-2012 02:59 AM
reverse gear..quick question.. Yaris2910 DIY / Maintenance / Service 10 01-11-2011 06:14 AM
Quick Oil Question nickhjort Performance Modifications 5 04-27-2010 09:51 AM
Quick question.. harveyjai Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-21-2009 06:38 PM
Lowering, shocks question... ToTo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 05-23-2007 12:55 PM
