Old 02-23-2013, 12:19 PM   #1
PDFileKyle
Drives: 2008 Yaris SE
Wheel, tire, offset, and lowering spring advice.
I just bought some 15x7 wheels with a 42mm offset.
I decided to go with some 195/60/15's, and then had the bright idea to order the Megan Springs.
The reason for this post:
(I'll admit it now) I have no idea what I'm doing. haha I've been researching the forums relentlessly and thought I had it figured out, but I still have questions.
Will this set up rub? Will I have problems with install?
Also, will my wheels stick out or sit in too far with this offset? I want it to be fairly flush, or stick out to a minor degree.
PDFileKyle is offline   Reply With Quote
Old 02-23-2013, 01:29 PM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Wheels will sit in the fenders.
It won't rub. You're pretty safe.
Hope your name isn't short for P(e)D(o)FileKyle.
kidding.
Old 02-23-2013, 02:35 PM   #3
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
^ HAHA
like sugi said you should be fine that is a pretty sunken in wheel still
Old 02-23-2013, 05:13 PM   #4
InfamousDragon
Import King
Drives: 2012 Yaris Le
Man you won't rub and you won't bottom out. I'm on stock shocks and custom springs also bought Megan racing springs that I am Gunna put on later. Any way I'm throwing 16 deeps on the front and 17 deeps on the back and won't rub. Slammmmmmmmmmmmm it hahaha. I'm 4 and a half inches from stock and going lower so Dont trip you got clearence. The Megan strings give you only a 1 and a half in drop and you got the same size rims plenty of clearance.
InfamousDragon is offline   Reply With Quote
Old 02-23-2013, 07:51 PM   #5
PDFileKyle
kidding.
thanks for the info guys.
any tips on making the wheels sit flush with the fenders?
ie, which spacers should I invest in?
Old 02-24-2013, 12:17 AM   #6
racerb
These work best and don't harm your wheel bearings like regular spacers do...
http://www.penguingarage.com/HubSpacers/Spacer.html
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 02-24-2013, 12:46 AM   #7
PDFileKyle
racerb
Is it common to go 10 front, 13 rear?
I've read (and seen) that the rear wheels are further inset than the fronts, and I want to have that balanced look.
Old 02-24-2013, 12:50 AM   #8
InfamousDragon
Import King
I don't know about spacers for that cause I do wide body or stock no spacers. But yea good luck
Old 02-24-2013, 12:44 PM   #9
yPod09
All black everything.
yPod09's Avatar
Drives: '09 5dr All black.
The penguins are great, super easy install, but only work in the rear. You have to use a wheel spacer up front.
Go for 13mm in the back, I did 10, with a 38 offset wheel and wish I'd gone the extra 3.
yPod09 is offline   Reply With Quote
Old 02-24-2013, 01:16 PM   #10
PDFileKyle
if it's needed, what would be recommended for the front?
I've seen bad things happen with the Ichiba's, so I'm hesitant there.
Old 02-24-2013, 04:34 PM   #11
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
it all depends on your car. Not all Yaris' are aligned the same over the frame.
Colin Chapman disciple
Old 02-24-2013, 06:53 PM   #12
SKurj
Drives: 09 Yaris 3dr HB, BRZ
You won't need spacers on the front, the rear you will. I added the penguins in the rear. Its not flush but its better.
This is with same width rims and tein s springs
SKurj is offline   Reply With Quote
Offset and lowering on 205/45/16s driver centric Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 08-13-2016 11:09 AM
Wheel offset questions mehullica Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-06-2011 01:26 PM
need 17inch rim guidence chino_potato Wheels, Tires and Suspension Forum sponsored by The Tire Rack 46 04-09-2007 01:09 PM
