Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
Question about the TMPS
how do i change them out?
do I have to take them out from the inside of the tires? I assume that i can just change them over from one tire to the other with no problems, and that which wheel they come from doesn't matter because they trigger at when any tire pressure gets down to around 28 psi.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
You have to remove the tire to change it. If you move them from one set of wheels to another, it doesn't matter which goes where, as the Yaris TPMS doesn't keep track of tire position.
| Transmission Question | CMR | General Yaris / Vitz Discussion | 42 | 04-14-2010 12:38 PM |
| Side mirror compatibility question | kw531 | DIY / Maintenance / Service | 3 | 12-11-2009 10:09 AM |
| ctrl-alt-delete question & free anti-virus question | Shroomster | Off-topic / Other Cars / Everything else Discussions | 18 | 09-08-2009 03:57 AM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
