![]() Drives: 08 yaris Join Date: Apr 2013
A/C Compressor Install
Hello guys im looking for some info on the easiest way to swap A/C compressors. Any help or wright ups would be greatly appreciated. 2008 Yaris
Take a look at the "Air Conditioning" section of the service manual, which you can download on the Micro Image forum (http://www.microimageonline.com/foru...32-YARIS-FILES).
If the system is still charged, you will need to have it evacuated first to safely remove the Freon. Once that is done, you loosen the drive belt, disconnect the two hoses from the compressor, and then remove the four mounting bolts. Reverse the process with the replacement one, and then have the system purged and refilled.
ok thanks
| Help: A/C Questions | flamingchicken4 | DIY / Maintenance / Service | 11 | 12-29-2018 12:53 PM |
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| A/C Broken On My 2010 5 DR HB | ChilliwackGuy | DIY / Maintenance / Service | 15 | 07-14-2010 04:33 PM |
| Easy Defrost A/c running fix | billk | General Yaris / Vitz Discussion | 14 | 01-16-2009 08:53 PM |
