Old 02-28-2013, 12:05 AM   #1
A1phazu1u
A1phazu1u's Avatar
Drives: Black 07 Toyota Yaris Sedan
FS: Pair of Black Liftback Power Mirrors
I have a pair of power mirrors for the yaris liftback black. Pretty good condition.
$60 Plus Shipping
Will trade for nst water pump or alternator pulley, intakes or some sort of performance parts. Shoot me offers.
A1phazu1u is offline
Old 03-29-2013, 12:15 AM   #2
arnmask
Drives: 2009 Yaris Hatchback
Will it fit 09 yaris hatchback?
arnmask is offline
Old 03-29-2013, 12:17 AM   #3
arnmask
Pm
arnmask is offline
Old 05-11-2013, 04:45 PM   #4
As an FYI, if you have a liftback without power mirrors, they are pre-wired for them, so all you need is the mirrors and the switch (which runs under $50 on ebay).
CTScott is offline
Old 05-11-2013, 06:55 PM   #5
MadMax
MadMax's Avatar
Hmmmmmmm.....do you have install instructions, Scott?
MadMax is offline
Old 05-11-2013, 08:08 PM   #6
I have a bunch of pics from when I installed a set on Crashy2, but it is quite easy to do:
Pop out the plate by the dimmer knob, insert the switch, and plug in the connector that is taped to the top area of the under dash fuse panel.
Remove the door panel, remove the two nuts that mount the manual mirror, feed the mirror harness through the door, plug it into the connector that is sitting beneath the door panel, and put everything back together.
CTScott is offline
Old 05-11-2013, 07:18 PM   #7
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Probably plug and play to be honest if it's already wired..
Betrivent is offline
Old 05-13-2013, 04:44 PM   #8
jcboy
Drives: Sedan 07
hi scott/OP, would you know if they can fit (or easy retrofit at best) sedans?
jcboy is offline
Old 05-13-2013, 05:46 PM   #9
Theoretically they should be an easy retrofit for the Sedan as well. The thing you want to do is to check for the presence of the connector which will plug into the switch. If that is present then the wiring is present. If it is not, then it is not as plug and play as it is with the liftbacks.
CTScott is offline
Old 05-15-2013, 02:25 AM   #10
A1phazu1u
A1phazu1u's Avatar
It won't work man, sorry. The reason i'm selling is because i bought these thinking i could use them for my sedan and there are too many differences to have these retrofitted to the sedan.
Old 05-22-2013, 12:12 AM   #11
A1phazu1u
A1phazu1u's Avatar
Bump
Old 05-22-2013, 12:29 AM   #12
I'll take 'em if you'll bring 'em.
cali yaris is offline
Old 06-03-2013, 03:03 PM   #13
toddo
toddo's Avatar
Drives: 2009 LB
Are these sold or still available?
2009 Yaris LB Carmine Red (Very manly thank you)
2006 Porsche Cayman S
2008 Honda Pilot EX-L
1996 Ducati 900SS
toddo is offline
Old 07-22-2013, 07:20 PM   #14
D&D
It's Quacktastic!
D&D's Avatar
Drives: '07 Yaris Hatch
I will PayPal immediately if these are still available..
D&D is offline
Old 07-23-2013, 08:47 PM   #15
auxmike
auxmike's Avatar
Still for sale?
auxmike is offline
Old 07-25-2013, 09:22 AM   #16
nevplus
Drives: 2008 vitz rs
sorry guys i bought them a little while back so they are definitely gone, i guess the original poster hasn't gotten a chance to update.
nevplus is offline
Old 07-25-2013, 10:59 AM   #17
D&D
It's Quacktastic!
D&D's Avatar
Thanks for the update! :)
D&D is offline
Is concenience package and power package the same thing on liftback ? YarisBlazer General Yaris / Vitz Discussion 4 07-21-2006 11:58 PM
Liftback with power package rchowelljm General Yaris / Vitz Discussion 14 06-23-2006 10:51 AM
