![]() ![]() Drives: 2010 Yaris sedan silver Join Date: Jul 2012
Down Sizing
Hi All, Would there be any noticeable change in acceleration, and handling going from the stock 15 inch wheels and tires to the 14 inch ones? Just curious.
I have the sedan if that makes any difference I had read some where before I bought her that the gearing was not the same as the hatch, but I don't know if that's true.
k&N Pannel air filter Trd Exhaust Trd Rear Sway Bar |
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
Weight has a factor too, if the smaller wheel weighs more it will require more torque to make a rotation and will cover less ground per rotation so it could be detrimental to acceleration
やりすぎだ~
^ actually, quite the opposite.
Right, if anything the smaller wheel and tire combo should weight a bit less, which would require less torque to rotate. Thus increasing torque I guess?
Form>Function
yea that is exactly what I was saying ^^ you have to make sure the 14s weigh less, if they weigh more it would be bad for acceleration... notice the "if"
Just because it is an inch smaller in diameter doesn't automatically mean it will weigh less. If you went from a lightweight aluminum wheel to a steelie, it could very well weigh more.
Making your wheels smaller (overall diameter of the wheel/tire) is the equivalent of increasing your gearing and thus giving you more torque but at the cost of lower top speed and thus making your motor turn a higher RPM for a given speed. I was thinking of changing the gearing on a pickup truck that I had (for acceleration). I was going to go from 3.55s to 4.10s. I was told to get a feel for what it would be like, I should swap out my wheels from the stock 29.5s to 26 inch racing tires (those are overall diameter). I ended up just swapping the gears and the acceleration and takeoff were awesome... I lost about 3mpg in the process. If you are using 14" wheels with meatier tires where the overall diameter is the same as the 15s, then disregard all that I have said. you would get weight savings with that only. |
#7 | |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
Even if the weight is the same, there could be a difference in rotational inertia. The 14" wheel will have the mass of the rim closer to the center of the wheel and will therefore require less effort to accelerate. The 20's on the truck in my icon hurt acceleration fiercely, but they look cool. |
| Window sizing for ventshades | schreck | General Yaris / Vitz Discussion | 1 | 05-20-2009 07:40 PM |
| Another one of those threads - tire sizing | 33OH | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 42 | 05-20-2009 04:57 PM |
| Appropriate wheel sizing | edie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 03-06-2009 11:50 PM |
| Hydroedge Sizing | tomgeorgia | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 11-29-2008 05:56 PM |
| Rim sizing - what size to get for OE equivalent? | jay | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 11-20-2006 03:25 PM |
