Old 12-06-2013, 10:36 AM   #1
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
Lightbulb sliding sun visor anyone ?
My sedan, 2010, has less than liked non-sliding sun visors. You know, when traveling due North or South and the sun hits just so ? Some cars have a sun visor that not only flips out it slides out and becomes longer. Is there a year model out there that has a sliding visor and if so, will it fit ?
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires
TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
JimKellyfan is offline   Reply With Quote
Old 12-06-2013, 11:19 AM   #2
07 and 08 had sliding ones. They are readily available on ebay for about $30 per side. Toyota did away with them in 2009 and the speculation is that it was because of the curtain airbags.
Old 12-06-2013, 12:40 PM   #3
Yaristeve
Drives: 3-door hatch
My 2011 3-door has slide out extensions in the sun visors. The passenger side is effective but because of the angle of the mirror, the driver side is blocked by the mirror so does not slide out enough unless you move the mirror and then you can't see behind you.
I would just apply a piece of black vinyl on the windshield behind the mirror. Although I may stick on a big TRD sticker on the windshield, 1980's style
Old 12-06-2013, 12:43 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
my 07 yaris does not have sliding sun visors.
BUT.. the area that the sun visor doesn't cover have these black dots around the rear view mirror.
Old 12-06-2013, 04:27 PM   #5
nookandcrannycar
My Yaris has both (the black dots and the sliding visor extensions). In the SF Bay Area, I don't use the 'sliders' very often, but here in the Houston metro (so flat....angles seem to matter more) I use them all the time and haven't felt the need to augment their performance.
Old 12-10-2013, 11:53 AM   #6
JimKellyfan
Thanks, I will start looking, now I know, some 07's, and 08, and 11's. When I am headed down (or up) Rte. 77, it is a need, and it is just out of reach currently. It will be a nice add on.
Old 12-10-2013, 12:19 PM   #7
I think you will find that even with the pre-09 ones that ones with the curtain airbags do not have the sliders and ones without them do.
Old 12-11-2013, 09:40 AM   #8
JimKellyfan
Yeah, they should themselves slide out, rather than have plastic extenders that can shear or impale on impact. But, if we are getting hit in the side, I think the little plastic extender will be the least of the concern at the time. But, great observation, as I was wondering what the reason for not having them or having them all the time was. It looks as if some Corolla's will fit. Next wonderment, is did the Corolla's come with any that slid out themselves and not had the extenders ?
Old 12-12-2013, 08:24 AM   #9
MileyRickens
Drives: MileyRickens mini van
Send a message via AIM to MileyRickens
Check out this link on sun visor. Its probably the next best thing..
http://www.cnbc.com/id/101083744
best buy vacuum cleaners
MileyRickens is offline   Reply With Quote
Old 12-12-2013, 10:53 AM   #10
JustPassinThru
Drives: No more Yaris
There's a simple way around this. Just get a sheet of thick paper, fold it around the sun visor and put a rubber band around the visor. When the sun is hitting just so, slide the paper over like you would the visor slide.
Inelegant, but a lot less work and cost than getting slides on the visors.
JustPassinThru is offline   Reply With Quote
Old 12-12-2013, 12:52 PM   #11
Yaristeve
I don't think that is/was the logic. My 2011, 3-door has the curtains and the slide-out visors and the little black dots. But the little black dots are totally useless. Toyota should have just painted that area solid black. I mean, how many times does anyone look through the space between the mirror and the roof?
Old 12-14-2013, 11:55 AM   #12
JimKellyfan
Cool
So does your 2011 slide out as a whole ?
That would be the only kind I would buy, as the ones with the plastic extenders were omitted for good reason (they probably hurt the crash dummies in a manner we would choose to not visualize)
too late
Old 12-14-2013, 05:26 PM   #13
Yaristeve
too late
No, on my 2011, the whole visor does not slide. Just a plastic extender that tucks inside the visor slides out and makes the visor wider (somewhat). The slides are only about 4" tall and slide out like 5". They don't need to be much larger since they cover the space above the mirror fine. I've never used my visor to the side.
Old 12-17-2013, 09:45 AM   #14
JimKellyfan
ok, thanks.
I couldn't possibly convince you to give rough tape measurements of the closed visor and clip distance from mount or edge of visor, could I ?
Old 01-15-2014, 11:48 PM   #15
Yaristeve
ok, thanks.
Sorry this took so long; hard for old geezers like me to figure out this newfangled digital carp. These photos should show how the extension works (behind mirror) and how long it is (2nd and 3rd pics).
Old 01-16-2014, 10:31 PM   #16
Kar98
Drives: 2011 Scion tC
I never use them behind the mirror, but damn are they ever freaking useful when the sun is coming from the left, like every time I'm going home.
Kar98 is offline   Reply With Quote
Old 01-17-2014, 09:41 PM   #17
nookandcrannycar
I use them the way you do, and also behind the mirror. There is something about the position of the sun, the angles, and the terrain in your area and here that prompts effective use of those slide outs. I've also noticed the same phenomenon in the LA/Orange County area when away from the mountains. Mine look like the ones in Yaristeve's pictures.
Old 01-28-2014, 11:14 PM   #18
JimKellyfan
thanks much !
Inside the Sun Visor, with Pics azeeroth Cosmetic Modifications (Exterior/Interior) 3 04-20-2014 04:28 AM
Brainstorming: Automatic Sun Shades supmet Cosmetic Modifications (Exterior/Interior) 6 10-28-2010 06:05 AM
Custom Fit Sun Shade for the Yaris Liftback tomato General Yaris / Vitz Discussion 24 06-29-2009 02:18 PM
Coolant Smell after sitting in hot sun? Snappy General Yaris / Vitz Discussion 3 05-31-2009 01:18 AM
The 2009 Southeastern Sun and Shinefest redyaris Southeast 24 01-11-2009 03:49 PM
