Old 09-02-2014, 08:43 AM   #1
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
03 Echo..cv joint
Whats a ball park figure $$ of what its going to take to replace it?
thanks.
Have Yaris will travel..
Old 09-02-2014, 11:10 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Estimates should be 2hours to replace the CV joint i think.
At least, that's the time needed to remove the axle to replace the the seal gasket on the transmission...
Old 09-03-2014, 04:12 AM   #3
jambo101
jambo101's Avatar
$3-4 hundred dollars? Ouch..
Old 09-06-2014, 05:12 AM   #4
jambo101
jambo101's Avatar
Update.
Seems a small section about the size of a slice of bread of the inner fender liner had fallen down and was rubbing against the tire when making hard left turns.
The mechanic cut the offending piece off, no charge..
Can I use a set of 185/65/R14 tires on Echo? Echo123 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-28-2013 08:48 AM
Worst Cars of the 2000s (#4. Echo) MadMax General Yaris / Vitz Discussion 34 11-12-2009 10:41 AM
Toyota Echo and Yaris TWM Short Shifter Sale! TWM Performance TWM Performance 3 08-24-2009 10:50 AM
Yaris and Echo short shifters sale, $30 off! TWM Performance TWM Performance 8 11-17-2008 02:23 PM
