![]() ![]() Drives: Toyota Yaris Join Date: Aug 2011
Installing MI Crank Pulley?
Well I'm going to install my MI Crank pulley again.
Last time I had a glazed belt and that just caused issues so i removed it and re-installed the factory one because I thought it was the pulley it self. But I'm thinking I had the belt too loose/or too tight. Just have some questions. I got a fairly new serpentine belt (oem with around 5000kms on it) so that should be good with the pulley im guessing? Also when I have the new pulley installed, I should probably be able to only twist the belt 90 degrees? Or is their another way I can tell the proper tension on it? Also after I have the car idling for 10 minutes or so with the new pulley on, should I re-adjust the belt? Thanks you. |
The belt shouldn't deflect more than 1/2" when you press on a long section of it
Twisting isn't a good measure. Deflection (how far you can press against the belt is the proper measure). I don't remember the exact deflection measurement off the top of my head, but I posted it in a couple of the other belt threads.
There is a real tool for measuring deflection, but I prefer to use my finger tip. Pressing on the middle of the long stretch of the belt with your finger tip the belt should only deflect the amount of the rated deflection.
![]() Drives: 2007 Yaris HB Join Date: Dec 2011
Please post pics of the install! I may be getting one soon!
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
I believe that because the belt already has 5000 kn, no readjustment would be necessary.
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
skill of the craft
I think this belt adjustment is skill of the craft old school kinda way. It shouldn't be too loose or too tight. definitely not too tight cause it'll ruin other components like...ie idler bearing or alternator bearings, A/C compressor bearings. If Toyota had installed the proper auto tensioner pulley in there we wouldn't be having this conversation....LOL
#7 | |
| Micro Image crank pulley - prototype complete! | cali yaris | Micro Image | 111 | 11-10-2014 11:24 AM |
| NST OEM Lite Crank Pulley or NST 10% Underdrive Crank Pulley 1.5L | Tylermayer | Performance Modifications | 2 | 06-02-2011 09:03 PM |
| NST Lite Crank Pulley | camelll | Items for Sale by private party | 5 | 03-15-2011 09:57 AM |
| NST Crank Pulley Swap/Trade | The Architect | Items for Sale by private party | 2 | 11-16-2010 02:11 PM |
| NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) | NonStopTuning | NonStopTuning | 266 | 09-29-2007 03:51 AM |
