![]() ![]() Drives: yaris sedan Join Date: Oct 2008
park light switch
i am having a problem with my parklight switch. sometimes it comes on normal then sometimes i have to turn it off and on a couple times before it comes on. also when its on it cuts off by itself.
note this is the one that controls the headlight. |
It could be the switch itself, the headlight switch connector having a loose pin (wiggling the connector can test for that), or the T-LP Relay.
Does it do it just in parking light mode, or also when the headlights are on?
just in parklight mode. when i turn it on the dash lights flashes on and off very fast.
if i turn for headlights the headlights come on but the parklights remind off. |
I would check the connector first. Remove the lower steering column cover and you'll see the connector at the base of the switch. Wiggle each wire a bit with the switch in the parklight position and see if anything changes.
#5 | |
I got a headlight switch from a crash yaris to try. Good new was that it worked. But I was wondering how difficult would it be to swap this part. |
#6 | |
https://www.youtube.com/watch?v=LgWS...gpsDA&index=17
Thanks much
By chance do you know where i can get a set of headlight with fogs stack and wiper (pirus) stack? Note I have a RHD yaris |
#8 | |
http://www.ebay.com/itm/TOYOTA-VITZ-...item4ac1e8c0e6
Thanks again. I will check it out.
![]() Drives: 07 Yaris Join Date: Oct 2013
Sorry for brining this post back to life, but I am also experiencing several lighting problems, which I narrowed them down to the T-LP relay.
I also have a 2007 RHD Yaris, and I was wondering where exactly this relay is located, or how it looks like. I've been through the car's service manual, it has very useful information, but when it came to helping locating the actual relay it was not of much help. Thank you |
#11 | |
Oh, ok.
Thank you for your quick response though. Well, what I am looking for according to the service manual, appears to be the T-PL relay. I will keep on looking |
OK - The T-LP relay is located within the body ECU, so theoretically the only way to replace it is to replace the entire body ECU assembly, which is that whole under-dash fuse panel piece.
#14 | ||
The good thing is that looked further into the technical manual, and T-LP doesn't fit 100% the symptoms of my problem. Could you please have a look into my problem? Hopefully it might be something simple for someone with your experience. Quote:
Thank you |
#15 | |
You can do an easy test to see if it is the relay or the headlight switch. The picture below is of a US Yaris headlight switch connector, but your looks the same, with possibly some wires in different positions. To test the relay with bypassing the switch, using a paper clip or piece of wire, jump the position 10 and position 13 wires. In the picture below that would be the bottom left wire and the wire 3 positions to the right of it. Conn d4.jpg
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 01:59 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 02:50 AM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 04:41 AM |
| replacement fog light switch? | yrsdrgn | Cosmetic Modifications (Exterior/Interior) | 4 | 07-17-2007 05:11 PM |
