Old 11-11-2013, 11:37 PM   #1
89GLH
Drives: 2009 Yaris 4 door hatch
09 HB Micro Image fogs question
I have several pending emails with them, first and foremost. Has anyone found a stock switch instead of the round switch I have to drill a hole in my dash for? The site shows this one, which is why I ordered it:
And what I got was a round one with a fog light sticker. Weak.
89GLH is offline   Reply With Quote
Old 11-12-2013, 12:05 AM   #2
The switch in your picture is the typical type that is included with the aftermarket fog light kits and what used to be included with the Micro Image kit. They are poor quality switches and required internal modification to make them work properly with the OEM wiring. The round switch is a higher quality switch which isolates the switching and the illumination (unlike the rectangular switch, which has them internally bridged).
If you would like one of the switches from your picture, I can ship you one, as I have a pile of them on hand from when we modify the aftermarket kits to build the plug and play harnesses.
Old 11-12-2013, 07:43 AM   #3
89GLH
Understood, I appreciate the quick reply! I'll hide this thing under the dash or something I guess. I didn't see any threads about how crappy they were. MI needs to throw a note up on their page, I could have saved a noob question :/
Old 11-13-2013, 11:00 AM   #4
89GLH
I followed the instructions perfectly, and they only work independently of the lights. No clue why that is.
Old 11-13-2013, 12:34 PM   #5
Which method in the instructions did you use? Letter "a" is the one for having them work in the OEM mode, where they only come on with the switch and only with the low beams on. Just to verify that we are talking about the same set of instructions, attached is the set I am referring to:
Micro Image 06-11 Yaris Plug-n-Play Fog Light Kit Installation.pdf
Old 11-13-2013, 03:43 PM   #6
89GLH
Same instructions. It might be the lack of description in that document. ONLY the OEM default will turn off with the car, all the others power independently? Now they turn on with no key in the ignition, totally independent of the car. Not necessarily a bad thing, just not outlined therefore I wasn't expecting it.
Old 11-13-2013, 04:38 PM   #7
IllusionX
Drives: 07 Yaris Sedan Aero
CTScott, might want to include the part numbers for those who want to have the fog light switch in the stalk.. like OEM.
Old 11-13-2013, 09:35 PM   #8
TOLMACH
Drives: soarer
As a second opinion.. I bought an ebay type kit. Wiring was very straightforward (even though one has to run a wire through the firewall). The only concern was quality of the relay.
Old 11-14-2013, 12:08 AM   #9
CTScott wrote the instructions, and they have successfully worked for many customers. I'm sure he can guide you through it to make the fogs light up the way you want them to.
I have changed the pictures on the website. When you didn't get the switch you wanted, you were/are welcome to return the kit -- but it's true that the round switch is better quality, and looks great when installed properly.
Seems to me you have passed on the offer of a free "OEM" style switch - yes? I'm happy to send you one as well.
Old 11-14-2013, 10:04 AM   #10
89GLH
Yeah, I'll pass on the OEM one. I greatly appreciate the offer. If this one is of higher quality I'd rather not be irritated down the line. This kit is perfect in every way. Fitment was perfect, where to wire and the quality of the components is top notch. My only issue was some of the wording, which was misleading (ever so slightly). I hid the switch in the fold out pocket under the dimmer switch, no big deal.
Old 11-14-2013, 10:33 AM   #11
Let me know which parts you thought were misleading, so I can revise the documentation. Sometimes what makes perfect sense to me leaves others scratching their heads.
Micro Image JDM replica tails installed.. Kiteless Cosmetic Modifications (Exterior/Interior) 26 08-02-2014 02:49 PM
Micro Image Lowering Springs Question sparkin88 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 12-30-2013 06:05 PM
FEELER/FS: MICRO IMAGE lowering springs. lets make a deal! sasquatch Items for Sale by private party 2 04-25-2012 08:14 PM
Micro Image Short Shift Kit- prototype review mazilla Performance Modifications 124 09-26-2011 07:04 PM
Micro Image Fogs dzcab Cosmetic Modifications (Exterior/Interior) 8 07-06-2011 06:43 PM
