![]() ![]() ![]() Drives: peArL yAvItZ!! Join Date: Jul 2009
To Enkei RPF1 or not to??
Hi guys,
I am having a hard time if i should go for 16"x7 Enkei RPF1 or not to? Currently my set up is SSR Type-F 15"x6.5. My reason for changing is to increase the 6.5" to 7" width and use wider 205 tires. Anyone??
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres |
Form>Function
what is your ultimate goal? Do you race? Are you hoping to get better handling with a 205? they make a 15x7 i believe and you can run the 205 on that as well.
While the RPF1 is an excellent wheel, I personally feel that it is played out.
Form>Function
It still is one of the lightest wheels out there so for racing, few things beat it and I can understand the allure
agreed with the played out.. but like phil says, you can't beat the weight of that wheel for performance reasons.. but if this is his daily and no plans to do any form of racing. there are better unique rims out there for half the price.
Tried 15x7 Rpf1, cannot clear my 285mm rotor. Therefore I opt for the 16". I have tried 17" wheel with 205. It handle great but I loss the acceleration speed. :(
Now on 15x6.5, love the acceleration speed now and lighter wheel give much better braking performance. Not sure is the 16 rpf1 rim at 13.5lbs light enough for my acceleration craving. Currently my type-F is at 9.5lbs. I love current set up and I just want a little better road handling. Btw I am not tracking/auto crossing. Just love some street sprinting. ;)
#7 | |
I would go with the RPF1 and add a spacer/stud kit in the front. Its not much work and should solve your problem. You don't even have to remove the front hubs to swap out the studs, there is an indent in the knuckle that lets you slip them by. http://shop.microimageonline.com/Ich...s-SC-58805.htm The easy button to better performance would just be a tire change with your current wheels. The top 15" street tire in autox for about the last five years has been the 195-50-15 Toyo R1R. It seems small, but it works like a champ on light FWD cars, no other 15" tire has won a ST class Solo championship in years.
#8 | |
2ZR swap. DO IT! Ask how!
I ended up with the Tire Rack house brand 15x7 this past summer, about 13 lbs per wheel. I ran the new BFG Rival in 205/50R15 but had serious acceleration loss compared to my street setup (15x5.5 11 lb Mini Cooper wheels w/205/50R15 DZ101's). |
#9 | |
Yaris beginner
Two objects of the same weight and "shape/size", the rotational inertia will be lower in the one where the weight is most concentrated close to the rotation center. So, even if you have two wheels of the same total diameter, same weight, acceleration/braking will be better with the wheels that have a smaller rim, as the weight is closer to the rotation axis (or the biggest part of the weight). The trade off, I would say, is tire deformation on hard cornering, but in light cars like ours I would say that trade off is not as critical as on big heavy porsches/bmws... |
Form>Function
how does the ssr fit in 15" if the rpf1 does not?
As you can see the pics, the clearance is very fitting for my SSR 15". Due to the RPF1 15" rim design, the center section is very thick compare to semi-forge SSR.
The pics of the 16" RPF1 fit perfectly with 3 to 4mm of clearance. Where the 15" hit the caliper. ![]() In fact, the 15" RPF1 rim can fit over the 4 screws stud, the spoke can clear no problem. It is the round O rims that hit outside edge of the caliper. With some grinder, it might clear the 15" rim. Not sure should i take this option...
^ It's the spoke design with the rpf1. They will not clear BBKs without the use of spacers.
You can put 205's on your SSR's but they'd look a little better with 7". I wouldn't grind wheel spokes to make them fit, unless I were shaving the hub or re-drilling.
The SSR is SO much nicer of a wheel. Just my opinion.
#14 | |
Form>Function
ahhhh got it.
^ Definitive answer.
Thanks guys for all the advices sir. Seem like 16inch is a big no no to me...
I'll start looking around for 15x7" rims. Maybe get the same SSR with 7" width or RPF1 to mod.it to fit... one thing I know for sure, nothing beat the lightness n acceleration of 15" setup. :)
| 17x7 Enkei RPF1 with 43mm offset wheels with 205/45ZR17 tires with DF210s, OK? | CtrlAltDefeat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 19 | 11-01-2012 04:29 PM |
| enkei vs 5zigen for yaris sedan 07 | gudboi182 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 02-28-2012 02:27 AM |
| Feedback requested: Enkei RPF1 & Yokohama S.drive | Iggy888 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 08-14-2010 07:14 PM |
| Rim Weights | bosbik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 11-14-2009 07:42 PM |
| Enkei Racing RPF1 | phenoyz | Willing to Buy by private party | 6 | 06-26-2009 02:40 PM |
