![]() Drives: sedan Join Date: Jun 2010
Help!! Alternator won't come out !! :o
I just wanted to ask if the bottom bolt on the alternator is reverse threaded? I've been trying to loosen it for 20 mins and the bolt is starting to round.. Broke a snap on 3/8 wratchet with a breaker bar.. Sprayed with penetrant since the start..
Bolt is the one below the alt pulley in the pic.. Thoughts or input appreciated !
As usual a little break to post up results in it coming loose :). Moved the alternator all the way towards the motor for a little more room and a quick turn snapped it loose.
Original alt and belt 255k km. |
Wow! You are lucky it did not snap.
Yep, I had to use a SnapOn 4 ft braker bar, and a 6 pt socket that I machined down, as to grab as much bolt head as possible.
That bolt got a couple of gallons of NeverSez before it went back in.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
#5 | |
I think a little bit of belt dressing over the years really helped. Bought the car in fall 06. 7 years and the mileage.. And the belt isn't brittle or very hard. Starting a few years ago anytime I heard a tiny squeal at startup or under accessory load I gave it a tiny spray of the stuff. My theory is that it really helps prolong the life.
Charging light is gone and after a few long drives , no squeals and battery seems to be charged right up. Was hoping the weak alternator didn't kill the battery since these two work hand in hand it's always best to have them both up to par. |
#6 | |
Agreed, my lower alt bolt is going to snap when it comes out... hope I don't have to change it when I don't have a lot of time to work on it :/
